Old 04-28-2019, 09:07 AM   #1
Sealant, roof - after replacement
Last year our coach went back to the factory for a roof replacement. When it came back we noticed that the front (cap area) leaks. We have contacted Forest River and they tell us to reseal the seam where the roof meats the front cap.
Upon visual inspection, the seal looks good. But, it still leaks... What would be the best caulking to use here?
Many thanks in advance!
scusset1 is offline   Reply With Quote
Old 04-28-2019, 09:12 AM   #2
Witch Doctor's Avatar
I would put 6" wide esterbond tape over it instead. (Spelling on tape) wrong, you can get it on Amazon. I would do the front and back caps, then you never have to worry about it again.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-28-2019, 09:14 AM   #3
brookstone345sa's Avatar
Eternabond tape. Just wipe clean first. Goes right over caulk thats there
brookstone345sa is offline   Reply With Quote
Old 04-28-2019, 09:45 AM   #4
rsdata's Avatar
Eternabond
read all about it here
EternaBond
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 04-28-2019, 10:04 AM   #5
007matman's Avatar
Here's a link to the 6" Eternabond I purchased for my camper.
WHITE Eternabond Mobile Home RV Rubber Roof Repair 6" x 10' - 10 Foot, 10 Feet https://www.amazon.com/dp/B077SHW98Q..._BcCXCbPNSZAVN
007matman is offline   Reply With Quote
Old 04-28-2019, 04:04 PM   #6
Garrette's Avatar
I would tell FR, NO. It is their responsibility to replace a leak free roof. Tell them that a roof from RVRoof.com will satisfy your roof issues and you do not want your RV back at the factory while you make payments. If this is a dead end than Eternabond tape is a good way to go.
If you want to caulk. Dicor and Sikaflex make good self leveling caulks. This is what you want on the roof but, make sure it is compatibile with your roof material. I know Dicor makes self leveling caulks for fiberglass and rubber/TPO.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
replacement, roo, roof, seal
