Old 03-21-2017, 08:18 AM   #1
Sealing New Exterior Attachments
I am needing to replace some different items and was wondering if these use Dicor Non Leveling sealant or Butyl Tape on these.
(4) grab handles
(2) door catches
several compartment door catches
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
Super8mm is offline   Reply With Quote
Old 03-21-2017, 08:30 AM   #2
jeff64's Avatar
If you are taking them off and redoing them, butyl tape would be my choice. Don't over torque, it will migrate over time and can be tweaked a little bit. From your pics, I might just tweak the screws a little, wash it off good and be done with it. Your call
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-21-2017, 08:41 AM   #3
Thanks Jeff64, the problem with the handles is that they are detonating pretty bad and the other are just broken.
For a 3 yr old unit it was not taken care of very well before I got it, but then I am retired so I have the time to do all the little things
2013 Puma 356QLB
Days Camped 33
Miles 6450
Old 03-25-2017, 08:59 AM   #4
Crockett's Avatar
I like lexel for a sealant, clear tube at ace. Look for foam instead of butyl behind windows, be sure to caulk these. The broken items are available in metal.
Crockett is offline   Reply With Quote
Old 04-04-2017, 09:05 AM   #5
I used butyl when I did mine.
ray98 is offline   Reply With Quote
Old 04-04-2017, 09:25 AM   #6
Butyl tape X4 here,
And as Crockett said, get the metal replacements when you can.
WeDidItRvay is offline   Reply With Quote
exterior, seal
