Sealing Outside Window Frame
It appears the outside window frames have a rubber or foam rubber seal behind them but there is still a gap around the window frames. How many of you run a bead of sealant around the top and sides of the window frames and what product do you use.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
