Old 03-31-2009, 06:59 AM   #1
Question seam sealant
Going to go over all the seams on the TT, Is the pro-cell that camping world sells the best, or is the flexable siding caulk at the home store going to work? Not against ordering, but I have some of the white siding sealant!
walkerdog is offline   Reply With Quote
Old 03-31-2009, 07:42 AM   #2
Head Rambler
According to most people you should never use silicone sealant on the RV. I agree with them. I use Dicor self leveling sealant for the roof and Dicor non-sag sealant for any vertical surfaces. ProflexRV is a good sealant as well. When recaulking windows the window should be removed and the butyl tape should be replaced. This is the only way to ensure a watertight seal. The same goes for storage doors.
Gotta go campin!
Old 03-31-2009, 10:41 AM   #3
cat1956's Avatar
I agree with Bama Rambler. I keep one tube of Dicor self leveling for the roof and one non-sag for every thing else.
cat1956 is offline   Reply With Quote
Old 03-31-2009, 11:08 AM   #4
NWJeeper's Avatar
I have only used Dicor as well, usually keep a tube of it and a caulking gun with me on the road, just in case...
Ed & Wendy
www.nwjeepn.com
Old 03-31-2009, 11:12 AM   #5
milzat's Avatar
For Roof - Dicor brand Self-Leveling Roof Sealant.
Vertical Surfaces - Geocel 2300 MHRV Vehicle Body Sealant . (this is what FR uses during assembly)
milzat is offline   Reply With Quote
Old 03-31-2009, 11:37 AM   #6
cat1956's Avatar
Never heard of Geocel 2300. Will have to check into.
Old 03-31-2009, 11:57 AM   #7
milzat's Avatar
Geocel Home Page
Geocel 2300 MHRV is sold to the public under the name Proflex RV.
Look for this product at most Ace, Do-It Best, Trustworthy Hardware, Sentry Hardware, Menards, & Camping World.
A word from Geocel Customer Support:
You do not have to tear out any of the old for the uncured will stick to
the cured beads .
I don't know. I'd at least try to remove as much old sealant as possible before applying new.
Good Link Here
Old 03-31-2009, 01:17 PM   #8
I was planing on cutting the dried butyl and running a small bead along the seams like i've seen done with other TT's. The local dealer actually was going to do this to a last years model I was looking at.
Old 03-31-2009, 03:39 PM   #9
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by milzat View Post
Geocel Home Page
Good Link Here
Thanks for the link. I've been looking for a good sealant for my windshield. I have a small area that opened where the sealant comes in contact with the rubber around the windshield. I couldn't find anything that would continue to stick to it, even the stuff used by the dealership popped loose. I plan to use a cleaner on the rubber and then the new sealant. I'm glad it comes in black as well. Thanks again, Charlie
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-30-2010, 08:47 PM   #10
Milzat,
Do you know if that white or brilliant white that FR uses?
phoneman06 is offline   Reply With Quote
