Old 03-17-2016, 09:11 PM   #11
davel1971's Avatar
how long is your bed? If it's a 1/2 ton, probably super short.
David & Lynn
Old 03-17-2016, 09:12 PM   #12
Grace looking to happen..
Thanks, "Old Coot" from another "Old Coot" - at least I know I'm not a total idiot - well maybe....
giantkillerbc is offline   Reply With Quote
Old 03-17-2016, 09:17 PM   #13
Could understand better if it was on the passenger side, BUT on the driver side???
Old 03-17-2016, 09:22 PM   #14
That is very odd. With my Reese Revolution and my SB truck the corners of the 5er can't hit the back of the truck since the pivot point is so far back (22" behind the hitch). From the photo you posted, the corner of the 5er actually hit the side pillar of your truck! That leads me to believe that the 5er was pivoting at the hitch and not at the Revolution pin box.
Is yours a true 6.5' SB truck bed or one of those super short boxes?
Did you have the wedge installed properly and the lock out bolts removed?
Who set up the hitch?
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 03-17-2016, 09:25 PM   #15
Justice12t's Avatar
I have a 6.5 and even without sliding I can still turn 90 to 90...it just doesn't seem right...can you provide some more pictures of the setup?
2016 Prime Time Crusader 294RLT
2018 F250 6.2l, CC, SB, 5th wheel prep, 4.30's, plow/camper package...ect
2016 Days Camped - 31
2017 Days Camped - 14
2018 Days Camped - 15
Justice12t is online now   Reply With Quote
Old 03-17-2016, 09:32 PM   #16
AquaMan's Avatar
6.5' is a standard bed, maybe OP has a 5.5' short bed.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 03-17-2016, 09:32 PM   #17
Left Coast
All depends where hitch in mounted in bed....front, over, behind axle. I have an 8' box where the hitch at rest is centered over axle. on a hard turn, the slider only uses 9" of the 18" of the slide......would like a sidewinder for even a little more clearance.
Old 03-17-2016, 09:42 PM   #18
Oklahoma Proud
MillerTime's Avatar
It still floors me that people try to turn that sharp.
It is extremely hard on trailer axles, tires and wheels turning so sharp.
Theres no shame in multiple point turns.
Old 03-17-2016, 09:44 PM   #19
davel1971's Avatar
8 foot has always been the standard bed. Then came 6.5 foot short beds. Shorter than that came to be when the crew cab 1/2 tons arrived. 1/2 tons always fall short on bed to keep their payload and GVWR in check, since everyone wants crew cabs these days.
David & Lynn
Old 03-17-2016, 09:47 PM   #20
davel1971's Avatar
That was my first thought also. It's not like you can turn your truck wheels 90 degrees to come out of that turn.
David & Lynn
bed, truck
