Old 01-13-2019, 04:20 PM   #1
Bako88fan's Avatar
Shower skylight leak
After a five day trip, we came home to significant rain. After two days, we went out to the trailer to clean and put items away and found a small leak from the skylight. It didn't seem too bad until I checked the ceiling and it was very soft. I opened up the skylight and noted that the luan ceiling and some of the 2x6 frame around the skylight was very wet and very soft. There were beads of water on the inside of the skylight that seemed to be condensation but upon reflection. Seems like water intrusion.
I'm going to remove the insulation after I reseal the outside skylight on the roof. The dicor on the roof has split so I'm replacing with Eternabond tape.
Does anyone know what type of wallpaper or vinyl I should use to replace the ceiling? Would anyone use a coat of resin on the 2x6" skylight frame to help it resist water damage? I'm going to remove any insulation that got wet because of the chance of mold.
Is there anything I'm forgetting? Click image for larger version
ID:	194521Click image for larger version
2008 Wildcat 29RLS
2016 Chevy Silverado 2500 HD
4x4 z71 Crew Cab Duramax/Allison
Bako88fan is offline   Reply With Quote
Old 01-13-2019, 05:05 PM   #2
A32Deuce's Avatar
My frame around the sky light was painted with a thick glossy paint. Almost like a brush on rustolium. My outside cracked and needed to be replaced. They use a butal sealant on the sky light.
A32Deuce is offline   Reply With Quote
Old 01-16-2019, 09:32 AM   #3
Jayhawker
Jayhawker's Avatar
Skylight
To extend the life of you skylight spray it with Krylon Fusion for plastic spray paint. No sanding or primer needed, and it will reduce the solar effect (excessive heat) in the camper.
Jayhawker is offline   Reply With Quote
Old 01-16-2019, 01:35 PM   #4
Head Rambler
Most big box stores carry thin vinyl coated luan paneling that you could use to replace the ceiling. I'd just replace the entire ceiling in the bath with it. I'd also paint the cut edges when installing it.
Gotta go campin!
Old 01-16-2019, 10:38 PM   #5
Bako88fan's Avatar
Good ideas, all
2008 Wildcat 29RLS
Old 01-17-2019, 02:24 PM   #6
Head Rambler
Just had another thought. Since it's in a high moisture area, I might see if I could find somewhere to buy Azdel panels. That would be very moisture resistant. I just looked them up and looks like they're about $50 a sheet not counting shipping.
Gotta go campin!
Old 01-17-2019, 03:13 PM   #7
Bako88fan's Avatar
Thanks! I was thinking about something like this due to moisture. I know it is easy to work with/cut.
Does anyone know - I want to seal the roof seam up with eternabond. Should I strip off the Dicor first?
2008 Wildcat 29RLS
Old 01-17-2019, 04:07 PM   #8
Head Rambler
Just get Eternabond that's wide enough to completely cover the lap sealant and don't worry about removing it.
Having said that, I would scrape some of the Dicor off the flange just to make the Eternabond smoother, just for looks.
Gotta go campin!
Old 01-17-2019, 04:10 PM   #9
Bako88fan's Avatar
Thank you. It looks like I've got a project for this weekend.
2008 Wildcat 29RLS
Old 01-17-2019, 04:47 PM   #10
A32Deuce's Avatar
See #2 about sealing sky light. I replaced mine and that's what I had to use.
leak, light, show, shower, skylight
