Old 09-24-2017, 08:31 PM   #1
Siding
Noticed the other day while towing my 2018 Forest River Wildwood that when I looked back at the camper I could see the siding bulging out. Should I be concerned and if so what should I do?
kawboss is offline   Reply With Quote
Old 09-24-2017, 08:52 PM   #2
crunchman12001's Avatar
yes, you should be concerned. 9 times out of 10, the factory cut the panels short or the staples popped. Take it in for warranty.
2015 F-250 FX4
Old 09-25-2017, 07:14 PM   #3
That's what I was thinking. Just wanted to be sure. Thanks
Old 10-06-2017, 01:46 PM   #4
JnScattle's Avatar
Does anyone have a temporary fix recommendation? Ours came out of the front seal on the port side while in the badlands. Right now I went to town with Gorilla tape.
Can I just start popping in machine screws to hold until we are too our new destination? Thanks!
______________________________
J & S
Traveling the world with Uncle Sam!
2014 2500HD Duramax Crew 4WD
2015 Forest River Salem 30QBSS
JnScattle is offline   Reply With Quote
Old 11-29-2017, 12:09 AM   #5
Mine ripped off in the wind in the same area the bad lands same repair of tape but removed the lower panel under warrenty 1 1/2 years old fixed by ft factory and some proplems with roof so they replaced roof great great service by factory so happy with our 2 nd forest river rock wood product
RAYSR is offline   Reply With Quote
Old 11-29-2017, 06:23 AM   #6
Raysr,are you sure your Rockwood has the SAME sides as what the OP is talking about? I have a WAG that the OP has "Panel Siding"! Youroo!!
Old 11-29-2017, 09:18 AM   #7
Mine has a slight bulge on the upper panel since new. No leaks or issues with the trim back there so far. (2016 model) I have seen several the same way.
While checking the panels I did find the markers lights, and others, to be poorly sealed. I recommend you check all your exterior lights.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
