Old 06-17-2013, 11:08 PM   #11
Herk7769's Avatar
Originally Posted by Xtrmtj View Post
If you have a trailer that was used with silicone caulk to seal. Is it fixable to put the correct caulk down and it work?
What would the correct removal process be to remove silicone?
Unfortunately it is very hard to get the silicone off and nothing will stick to it.
Once you have gone down this road, it is tough to turn around.
HAM CALLSIGN - KC3FFW
Old 06-17-2013, 11:12 PM   #12
Herk....so do I have no options to remove it?
2007 Yukon XL (AKA) LAND YACHT
2002 Rockwood Roo 23ft
1998 Jeep Wangler (lifted and modified)
2008 Pontiac G6
Xtrmtj is offline   Reply With Quote
Old 06-18-2013, 05:50 AM   #13
Herk7769's Avatar
Depends on how much I guess, and if what you have is leaking.
There are always options; some pretty extreme.
Pictures of the area would be helpful.
Old 06-18-2013, 07:08 AM   #14
Crusader's Avatar
900
This will out last anything
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 06-18-2013, 07:22 AM   #15
EastlakeRoo's Avatar
Originally Posted by dfskinner View Post
RV Leak Repair Tapes & Sealants | EternaBond
Friend introduced me to this product when the front of our trailer started delaminating up top on the front; caught it in time for it not to become a major issue. Used the eternabond to seal the joint going across the top. Traded the trailer in on what we have now, but I swear by this stuff; they have some other products on their website that might help
I agree on the EternaBond. Just finished applying the tape to all caulking on the roof while the caulk was still new. Shouldn't have to worry about re-caulking the roof anymore. This is the best preventative measure in my book.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 06-18-2013, 09:23 AM   #16
Send a message via MSN to Tiggerdad
Try wiping with Acetone or other quick evaporating solvent, alcohol may work but not sure, then apply a sealant like Dicor or Proflex. Dicor and Proflex has enough petroleum distillates to allow them to penetrate surfaces and adhere. Watch closely to make sure it does not come loose over time. Good Luck.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-18-2013, 12:26 PM   #17
Herk7769's Avatar
Originally Posted by Crusader View Post
900
The application list does not list rubber or EDPM roof material.
Old 06-18-2013, 01:10 PM   #18
I have attached a pic of one area I have. I have a ROO and need to seal the bunk end frames really well. The bunk pictured is being replace. But I need to go thru and clean all the silicone I put down in an effort to seal it. I was told by Dave Arbogast RV service just use Silicone, that is what we use. I think I was fed horrible info.
So I need to go and clean everything real good, and seal with a good sealant. What is recommended by all.
Please advise.
2008 Pontiac G6
Old 06-18-2013, 01:12 PM   #19
Herk7769's Avatar
I use Proflex for everything except the roof.
ProFlex RV Flexible Sealant - Product - Camping World
Old 06-18-2013, 01:20 PM   #20
daydreaming about camping
jeeplj8's Avatar
I have used this on a exterior shower to remove silicone and it worked quite well:
Amazon.com: Motsenbocker 411-45 Silicone Latex Caulk And Foam Sealant Remover: Home Improvement
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
