Old 06-21-2019, 07:53 PM   #1
Size for bathroom vent cover
I have a 2019 Sabre 30RLT not even a year old and the bathroom vent/fan cover has already deteriorated. Does anyone know the model or size I can buy to replace this? Or, is there one that is universal to fit? Preferably one that lasts longer than a year... Thank you for your help.
ID:	207916   Click image for larger version
ID:	207917   Click image for larger version
JeremywFL is offline   Reply With Quote
Old 06-21-2019, 08:30 PM   #2
WalMart online has them both white and dark .
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 06-21-2019, 08:39 PM   #3
I see there is multiple sizes, any idea on the size? Also, it be nice if they sell one that doesn't break so easily.
Jeremy
19' Sabre 30RLT
Old 06-21-2019, 08:45 PM   #4
As far as size you would need to measure yours and material wise I believe they are pretty much all the same. Usually last for years or at least mine have.
A vent cover is also nice , protects it from the sun and it can be left open during rain , etc.
Retired Navy
Indiana
Old 06-22-2019, 06:01 AM   #5
nomad297's Avatar
Your vent cover is a Heng's 90110-C1, 14”x14”. They cost anywhere from $14.00 to $25.00 and take minimal effort and skill to replace. All you should need for tools is a #2 Phillips head screwdriver, and maybe a vacuum cleaner to clean up the stuff that comes out of the ceiling while you are replacing it.
Start inside by removing the four screws that hold the trim flange to the ceiling, crank the vent open about half way, then remove the screw in the center of the crank handle. Pull the crank handle off. Now, remove the two screws that hold the screen flange in place. Pull down to remove the screen. Remove the two screws that hold the crank mechanism in place to the metal frame, then slide the arm that connects the crank to the lid over to the round part of the slot on the metal piece connected to the lid so you can detach the arm from the lid. Now, go on the roof with your new cover. Take the old cover off by sliding it off of the hinge — it should slide off either way with no tools (unless somebody bent the retaining tabs at the ends of the female part of the hinge attached to the cover, but they probably didn’t). If the tabs have been bent, just bend one of them back out of the way with a wide flat screwdriver, then slide the cover off, but I really don’t think you will have to do this. Now, slide the new cover onto the hinge attached to the frame. Now, the most important part is to chuck the old cover off of the roof onto the ground so you can watch it shatter into a million pieces. Go back inside and put it all back together in the reverse order of how you took it apart.
Easy!
Bruce
Old 06-22-2019, 06:53 AM   #6
jrk341's Avatar
https://www.amazon.com/Camco-40161-4...gateway&sr=8-3 This is what I put on mine.
jrk341 is offline   Reply With Quote
Old 06-22-2019, 06:55 AM   #7
jrk341's Avatar
https://www.amazon.com/Custom-V39-99...way&sr=8-2Then I put these over the roof vents.
Old 06-22-2019, 06:55 AM   #8
Mr. Dan's Avatar
“Deteriorated”, maybe... but that’s how mine looked after being hit by hailstones.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Old 06-22-2019, 07:33 AM   #9
jrk341's Avatar
Both of mine were "Deteriorated" and not from hail damage.
Old 06-22-2019, 10:17 AM   #10
Thanks for your help, below is the cover which is a 14" x 14". Camco sells one on Amazon for around $17 and they claim it doesn't break, so we'll see. Forest River needs to spend the extra $5 and put a quality vent on the roof. That's pretty ridiculous as this could've caused a flood in our unit.
https://www.etrailer.com/p-BV0554-03.html
Jeremy
19' Sabre 30RLT
bathroom, cover, roo, vent
