Old 05-22-2008, 04:52 AM   #1
skylight question?
I have the skylight in the bathroom in my 831krss. Has anyone has problems with condensation building up on the inside of the skyight? I noticed it the day i picked it up and the guy told me that it was typical of them to build up some moisture in them. He checked to make sure it was sealed well on the roof and said it was fine. I had a skylight in my Puma and it never had any moisture built up in between the skylight. I'm gonna take a closer look at it today and see if i can take it apart from the inside to dry it out and see if it happens again.
Anyone with suggestions?
eandsphotography is offline   Reply With Quote
Old 05-22-2008, 10:30 AM   #2
powerboatr's Avatar
if yours is like mine, the inside trim/window piece was not sealed. We to built up lots of condensation on the inside window.
i found out it was not sealed when i unscrewed it and it fell out. just a a hole with gasket of seal.
it has a nice foam gasket now.
DW also added a nice piece of foil bubble wrap stuff and wrapped it in a print that matched the cedar creek theme and attatched it to the screws using loops and it now blocks the bright SUN when i sleep late
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 05-22-2008, 12:43 PM   #3
Eand, we have the same unit as you and have not had that issue. I guess that is a good thing.
Steve and Michelle
two boys, and One yellow lab
831KRSS 2008
2004 Chev.Avalanche
Stelrs59 is offline   Reply With Quote
Old 05-22-2008, 02:03 PM   #4
milzat's Avatar
I've never noticed condensation in the bathroom skylight. I do know only the upper section is sealed to the roof.
I did something similar to powerbaotr. I remove the inner section and install a piece on thermal material between the two sections. This keeps the bathroom cooler in hot weather and warmer in the winter.
milzat is offline   Reply With Quote
Old 05-22-2008, 05:02 PM   #5
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Only once, but my skylight was cracked from a tree falling on it.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-22-2008, 08:25 PM   #6
well, today i took it apart and dried it out. Screwed it back up and within an hour condensation was building up in it again. It is in direct sunlight and was not raining. I just dont get it.
Old 05-22-2008, 10:42 PM   #7
The Jolly Mon
NDJollyMon's Avatar
Could there be a water leak up there somewhere...and it's moist ?
Pete (Jolly Mon)
Old 05-23-2008, 08:19 AM   #8
not sure. it was pretty warm yesterday so it didnt seem to be moist.
Old 05-23-2008, 03:54 PM   #9
j2detroit's Avatar
I have a 06 Cherrokee and althought my skylites are not in the bathroom We have not had any type of problem with them at all Ours are over the dinett and there is 2 of them 24 inches square They even stay nice and clean
j2detroit is offline   Reply With Quote
Old 05-24-2008, 06:08 AM   #10
KyDan's Avatar
Sure sounds like a water leak.
Have you gone over the outside flashing/caulking carefully to be
sure you don't have even the smallest leak up there??
Old 05-24-2008, 08:35 AM   #11
Bona fide Nut job
Winsurfer76's Avatar
I was having the same problem with mine. When I pulled the inside part off to clean, I noticed that a couple of screws were rusty. A little water from the hose and I found where the caulking was cracked. I used eternabond tape to the cover the edges and haven't had a problem since.
2005 Wildwood 28BGSS
Winsurfer76 is offline   Reply With Quote
