Old 06-27-2016, 10:23 AM   #1
Slide gaskets
Out on the road and I noticed that one of our slide gaskets has pulled free from what looks like a little bit of sealant and pulled itself out of the screws holding it down.
It looks like a simple fix except for getting a screwdriver between the slide wall and the screw head.
Yes it is covered under warranty but I'd rather fix it myself. I just don't see how to get to the screws. Am I over thinking it? Should I use sealant to reattach or is this going to be a major fix and I should let the dealer do it?
Sent from a field
opie is offline   Reply With Quote
Old 06-27-2016, 11:50 AM   #2
You should be fine caulking it back in place. However, you could try a right angle ratcheting screwdriver to get to the screws. It'd be a little slow, but it may work.
Gotta go campin!
Old 06-27-2016, 07:09 PM   #3
Thanks. I'm a bit skeptical on caulking holding it because right now when we extend the slide it pulls the gasket completely out of the wall and hangs on the outside.
Did I read correctly somewhere that folks "lubricate" the rubber with baby powder? I think that would help the situation tremendously.
Sent from a field
Old 06-27-2016, 07:56 PM   #4
Who Dares, Wins
doc73's Avatar
I do the inside seals with baby powder and the outside with silicone spray
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 06-27-2016, 07:59 PM   #5
Thanks.
Sent from a field
gas, slide
