Old 11-01-2014, 02:44 PM   #1
Slide outs
My slides will come in about hwlf the way.
And then stop.
After a few seconds you can push button ayainnand thet will continue to come in any ideas
cabinetmaker61 is offline   Reply With Quote
Old 11-01-2014, 03:33 PM   #2
Witch Doctor's Avatar
Have sprayed dry lube on the gear and tract?
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-01-2014, 03:42 PM   #3
offroad's Avatar
Battery fully charged, or hooked up to shore power?
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 11-01-2014, 08:10 PM   #4
Hooked to ground power.
Have sprayed a lithium grease on the tracks
Old 11-01-2014, 08:53 PM   #5
johngoat2002's Avatar
If it has an auto reset breaker, it may be going bad. Tracing down the wires to find out if it has a conventional fuse or breaker would be an easy way to rule that out.
johngoat2002 is offline   Reply With Quote
Old 11-02-2014, 07:26 AM   #6
Ok I will look for that the next time we are there.
slide, slide out
