Old 11-30-2017, 05:34 PM   #1
Slide seals
Anyone ever do maintenance on the slides UNDER the slide? Not as important but could cause probs if go bad. I clean and treat mine and look for debris annually.
quick83 is offline   Reply With Quote
Old 12-01-2017, 07:29 AM   #2
grumpy0374's Avatar
Oh yes, top, bottom, sides, inside and out.
Out, every other month.
Inside, twice a year.
Use 303 Protectant only.
5 year old Lexington, 3 slides, seals still as good as new.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 12-01-2017, 07:32 AM   #3
Grumpy
X2. Same here.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 01-30-2018, 08:08 AM   #4
Speaking of under the slides....my Isata3 has a gray flat material covering the entire bottom under the slide . Anyone know what it is made of!
NealM is offline   Reply With Quote
Old 01-30-2018, 08:44 AM   #5
I think mine is some type of pressed wood, like plywood.
Old 01-30-2018, 08:55 AM   #6
I wasn't referring to the floor under the slide.... Actually attached to the underneath of the slide is some gray material, perhaps to protect the plywood subfloor?
Old 01-30-2018, 08:55 AM   #7
On my Flagstaff slides, they are made of HDPE Poly Board.
Old 01-30-2018, 08:57 AM   #8
Ok thanks, makes perfect sense....
seal, slide
