Old 10-23-2017, 03:53 PM   #1
SOS - 2015 mini-lite leak
Stuck in a frog strangler in SW Virginia and water is starting to seep in from the hot water heater wall. I thought the blowing rain might be coming in from the hot water vent so I blocked that. Can't see anything in the trunk. I thought it might be plumbing but it increases with the intensity of the rain. I thought with these pressure sealed walls, there wouldn't be a way for it to wick from the roof to the floor. Any suggestions?
iamanomad is offline   Reply With Quote
Old 10-23-2017, 04:00 PM   #2
Flybob's Avatar
The water heater cover is not immune to blowing rain, but the unit itself behind the cover should be sealed with the walls especially along the bottom. If you have a fridge with a roof vent nearby blowing rain can enter that way,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-23-2017, 04:19 PM   #3
Thanks, the fridge is on the back of this trailer, so I am ruling it out. This is going to be a tough one to find unless there is something obvious on the roof or when I or someone more flexible can look behind the heater. Supposed to head for home tomorrow and it should be a dry drive.
Old 10-31-2017, 05:08 AM   #4
Update- I soaked both windows and put a hose full blast on the roof in several locations and couldn't duplicate the leak. I also managed to squeeze my old fat body into the trunk and couldn't see any evidence of water or past water damage. Time to check with the dealer I guess.
leak, lite
