Old 10-03-2010, 05:36 PM   #1
mTn_biKer65's Avatar
Stove vent (exhaust) door
I just arrived home from a camping weekend to discover that the stove vent door is missing. I must've forgot to engage the corner locks before leaving the park. In all honesty I didn't think loosing the door was likely if the locks weren't engaged during travel.
Anyhow, is the door replaceable or do I need to replace the whole vent assembly?
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 10-03-2010, 05:37 PM   #2
Hatchet58's Avatar
I had to replace to whole assembly
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline   Reply With Quote
Old 10-03-2010, 06:00 PM   #3
We also lost our vent when we left the corner tabs unhooked - never had that problem with our 2000 Terry. Have they redesigned the vents?
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 10-03-2010, 07:50 PM   #4
52Dodgeman's Avatar
Since it appears that you might have to replace the whole vent assy, I would suggest that you make a template out of cardboard and then cut a piece of 1/8 plexiglass to match. Should be a lot cheaper. I intend to attach a lanyard to mine so it cannot get lost.
2008 Flagstaff 831FKSS
1997 Ram 2500 4X4 360 Gasser
Wife Candice, two dogs
1957 Dodge D100, 315 Poly
Liberty Hill, TX
52Dodgeman is offline   Reply With Quote
Old 10-03-2010, 07:58 PM   #5
Hipshot's Avatar
I lost mine last spring also. My local dealer does not carry the exact replacement vent. I do not like the one they carry. There was a post on this forum about this issue. The poster made a vent door out of sheet metal and a metal rod. I plan on making one this weekend.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 10-03-2010, 11:15 PM   #6
I lost mine and dealer had the same one for only $5.00 so i bought the whole vent
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 10-03-2010, 11:19 PM   #7
Lost mine on my old Cedar Creek coming home from Maine. Made a new one out of aluminum. .060 thick, and just cut the ears on the end. You can flex it to engage the ears in the holes to hold it in place. Never forgot to check it after that, either!
MightyMike is offline   Reply With Quote
Old 10-04-2010, 08:02 AM   #8
BOBFIDY's Avatar
We got to the campground on our 1st trip and found that 1 of the pivot tabs was broken off. Guess we add that to out list of things to get fixed or figured out when we get back home.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 10-04-2010, 09:03 AM   #9
KyDan's Avatar
This is one of the most common complaints for RVs.
(Maybe not as common as concertone complaints but close!)
I also made one to replace mine after one tab broke off.
I've read somewhere where you can buy the door but you have
to remove the vent to replace it so why not just replace the whole
thing if it's only $5.
OTOH the new one is gonna do the same thing one day unless
you remember to latch the corners EVERY time.
They are made soooooo cheap. The maker could easily beef
up the tabs with a minor change to their plastic die but why
do that when you can sell more when they break.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
