Old 05-26-2018, 10:14 PM   #1
Streaking from rubber roof conditioner
After cleaning and conditioning my rubber roof last year, some of the conditioner left streaks on the nose of my 27RR, I tried black steak remover, didn't budge the streaks. Anyone else have this issue, what did you use to remove the streaks?
2018 XLR Hyperlite 29 HFS
2018 RAM 2500 6.4L HEMI
2015 H-D Ultra Triglide
2015 Polaris RZR 570
BKM1066 is offline   Reply With Quote
Old 05-27-2018, 12:05 AM   #2
Fiberglass nose?
I find almost anything comes off with Krud Kutter. It will literally take the color off the label of the spray bottle, but it lifts almost anything off fiberglass.
Make sure to test it on an inconspicuous area first.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-27-2018, 06:40 AM   #3
Had the same issue. Apparently I didn't keep the sides wet enough while using it, or perhaps is just washed down after a rain. Heavy rubbing while waxing (a ton of work) and even some polishing compound in some spots. Brutal. I did find some "Purple Power" later that removed spots I missed with a lot less work.
Rusty
lcv800 is offline   Reply With Quote
Old 05-27-2018, 06:40 AM   #4
Thanks, pretty sure it is fiberglass.
Old 06-11-2018, 04:04 PM   #5
vintage's Avatar
Did you find a solution? Thanks
2016 Grey Wolf 26RR Limited
2017 Arctic Cat Wildcat Trail Limited
2019 Dodge Ram 1500 Bighorn Crew Cab
5.7 litre Hemi 4x4
vintage is offline   Reply With Quote
Old 08-25-2018, 05:49 PM   #6
vintage's Avatar
Actually I believe the front nose material is aluminum..
5.7 litre Hemi 4x4
roo, roof
