Old 10-02-2014, 10:34 AM   #11
Evereddie's Avatar
Originally Posted by BombDoc View Post
I took other's recommendations on the forum and tried Totally Awesome. I purchased it from the dollar store in 1 quart spray bottles because the bigger gallon jugs were all sold.
Is that store actually call "Dollar Store"? Or is it Dollar Tree, or Dollar General, or Family Dollar, ....? I don't usually go to these type of stores but this product sounds like it does the trick for many.
Evereddie is offline   Reply With Quote
Old 10-02-2014, 10:41 AM   #12
Witch Doctor's Avatar
I know Dollar General carries it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-02-2014, 10:41 AM   #13
mud yapster's Avatar
X2 on the Totally Awsome stuff I need to get some and try it also
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-02-2014, 11:17 AM   #14
Dazed & Confused
M&K Hoffman's Avatar
Stores that carry Totally Awesome
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 10-02-2014, 11:32 AM   #15
Evereddie's Avatar
Originally Posted by MEHoffman View Post
Thanks! Sounds like all of them.
Old 10-02-2014, 02:45 PM   #16
I do know that you must be careful with roof cleaner on the sides and it must be washed off the sides with water very soon and not to let it sit on the sides. I don't know how you would stop the water from running off of the roof from the ACs, I have two of them and I would think that it is easier to clean the stains. Good Luck
whj77372 is online now   Reply With Quote
Old 10-02-2014, 02:53 PM   #17
Dazed & Confused
I have used powered Spic N Span mixed to strongest suggested mix and had great results cleaning the roof on my old trailer. Plan to use it on my new roof before winter as it was on dealers lot for several months before we purchased the unit.
~Mike & Kim~
Old 10-02-2014, 02:58 PM   #18
Old Enough to Know Better
gasman6674's Avatar
I use the liquid car wash soap undiluted on my old class C roof and it did a very good job. I used a 2 gal pump spray to put it on.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 10-02-2014, 03:17 PM   #19
Anyone try the baking soda and white vinegar trick?
rana is offline   Reply With Quote
Old 10-02-2014, 03:58 PM   #20
asquared's Avatar
Originally Posted by gljurczyk View Post
more then likely are you seeing kinda rust color? If you are staining it is coming from your Evaporator pan and coil needs cleaning, They make a coil cleaner. might help. As far as the roof, just plain old rubber roof cleaner.
Do you think that the coils need to be cleaned on a brand new unit? Again, purchased in July, built in Feb 2014.
I took other's recommendations on the forum and tried Totally Awesome. I purchased it from the dollar store in 1 quart spray bottles because the bigger gallon jugs were all sold. The lady in the aisle said they have a hard time keeping it in stock. My 5'er is 36' long and cleaning the roof is a JOB!!! I try to do it twice a year. The Totally Awesome works better than anything I have found previously, to include Tilex. Be sure to dilute it according to the instructions. I used it straight on tough stains and was very impressed. I purchased 4 quart bottles and used one on the roof with warm water mixed in a bucket. Dipped a brush in the bucket and went to town. Use plenty of water to rinse, I could see the places on the sides of the trailer where I didn't rinse well. It was hot out when I did it last and the spots where I didn't rinse well, left white streaks on the fiberglass sides. So, once I finished the roof, I did the rest of the trailer with warm soap and water. I was very impressed with the Totally Awesome. I am on 4 acres and parked under oak trees. Not a lot I can do about them, they drop leaves constantly. Good luck and post pics!
We use totally awesome. Used it on old tt with ok results. Tried it on the fiver, again only had it 3 months and couldn't get the stain off the roof. And yes you can get it at dollar General. That's where we got it.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
roo, roof
