Old 10-13-2017, 01:52 PM   #1
Sunseeker "decals"
2010 Sunseeker. Clear plastic decals on the front cap and above grill appear to have mildew or some growth under them. Can I remove these without damaging the paint? I have tried bleach, tar remover etc to clean, not happening
sheetshaker is offline   Reply With Quote
Old 10-14-2017, 08:55 AM   #2
SeaDog's Avatar
I have use a heat gun to remove decals with good luck however you must be careful. You might try stopping by a local body shop and ask what they use, who know they might be able to do the job for very little money
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-14-2017, 09:37 AM   #3
Retired JSO's Avatar
I used a wallpaper steamer and plastic putty knife to remove some years back with good results.
Retired JSO is offline   Reply With Quote
Old 11-06-2017, 03:42 PM   #4
hack522's Avatar
Possible remover
You may want to test a small area with denatured alcohol. Typically used to clean off the residual adhesive on windows. Soak it onto the decal and then try lifting with a putty knife.
hack522 is offline   Reply With Quote
sunseeker
