Old 07-23-2019, 01:09 PM   #1
Tightening frame and axle nuts
Any recommended maintence intervals for tightening frame, stairs and axle nuts? Ive not seen anything on this and maybe I'm missing it. Theres definitely no torque specs out there, maybe from Lippert for the axles?
Krabage is offline   Reply With Quote
Old 07-23-2019, 01:16 PM   #2
Oaklevel's Avatar
I have never tightened ours on any trailer so I'm interested in seeing what is said.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-23-2019, 01:58 PM   #3
A32Deuce's Avatar
All you need is the size and grade of the fastener and look up the torque chart and tighten to that torque. Axle should be grade 8.
A32Deuce is offline   Reply With Quote
Old 07-23-2019, 01:58 PM   #4
I suppose if you feel they may have been improperly tightened or you traverse rough roads regularly, then I suppose checking them might be a good idea.
Honestly, in over 40+ years I've not had frame or axle nuts come loose where general maintenance/checking would have been required.
With today's R/Vs and the seemingly endless shoddy workmanship from the factory, I suppose anything is possible though.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-23-2019, 03:57 PM   #5
Yes thats my concern, more so with the subpar workmanship and honestly who hasn't gone down a roigh road at some point. Everything gets loose at some point right.
Old 07-24-2019, 02:05 PM   #6
rlh1957's Avatar
Once a year I am underneath checking anything and everything for corrosion, rust, missing or hanging things. I have some Screwdrivers, pliers and adjustable wrench just to check on tightness of bolts or screws. Haven't found any, but have heard of others having factory delivered rigs with things that got loose. At the very least as part of your tire upkeep and maintenance the other side of tire under the rig is as important to check as looking at the out face of the tire you see when checking pressure. Also checking the torque on the lug nuts.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-24-2019, 04:33 PM   #7
I just replaced one of the axles on my 4 year old trailer. The nuts / bolts that hold the axle to the frame were quite tight. They were also lock nuts so not likely to loosen.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 07-24-2019, 06:29 PM   #8
Check wheel fender skirt stabilizer bars too
Every trailer owner should check the nuts on the bolts attaching the walls to the chassis, and the sheet metal screws attaching the wheel fender skirt stabilizer bars.
When I got my new trailer home, I found over half the nuts attaching the walls to the chassis were not tightened. I tightened them, and I recheck them every 6 months.
Just 2 weeks ago, I noticed in the mirror while driving that one of my wheel fender skirts was fluttering. The screw attaching the stabilizer bar to the wheel well had come out, leaving the bar hanging from the skirt, only inches from one of the tires. If it had caught on the tire, it would probably have shredded the skirt.
2018 Coachmen Viking 21RD
2012 Ram 1500 5.7L Hemi 4x4
Full-timing since October 2017
johntaylor is offline   Reply With Quote
Old 07-24-2019, 08:31 PM   #9
Hard to leave anything to chance anymore. Its good to hear feedback on what should be be done even though the mfg doesn't call it out. Theres plenty to keep track of and to me this is high on the priority list exactly for the reason you mention. Besides ive already adjusted both my entry doors, the 1st year shakedown right....
axle, frame
