Old 09-08-2013, 10:21 AM   #1
retiredguy's Avatar
trees and the hardwall
Hi. Looking for suggestions. While in storage a tree has rubbed up against the wall of our hardwall trailer. (likely under wind conditions as the trees were cut back) Looks like the "gloss" has been rubbed off in a spot about the size of a baseball. This would be from leaves and small branches... no scratches are evident ) Was wondering if this will polish out, or whether there is a spot gel/spray that can be spread back on this area.
Thanks ahead of time for any comments.
2013 Windjammer 3025
2018 Heartland trail Runner sle 265
2012 GMC 3500 6.6
2011 Razor 800
http://dougbevswanderings.blogspot.ca/
retiredguy is offline   Reply With Quote
Old 09-08-2013, 10:57 AM   #2
Witch Doctor's Avatar
You should be able to rub it out with some 3m products, you might still notice it because of you knowing where to look but it should come back up if you didn't get into the gel coat itself. I do not know of any gel coat spray, you might try West Marine. Gel coats on boats been here a lot longer then trailers. Even Marine polishes are better, but they will mostly recommend 3m products.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-08-2013, 12:13 PM   #3
Taylorgso's Avatar
No problem. Go to an auto supply store. Get a pack of 1500grit (or higher) emory cloth, and wet sand the spot and surrounding area, dry, then use the 3M fine cut polishing compound mentioned above, and do a final polish/wax. If it did not cut through the clear coat, it will be good as new. I've done this repeatedly to cars I've restored; learned it from a body/paint guy. Good luck with your repair.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
