Old 02-18-2016, 08:03 PM   #11
Find anybody other than CC for your carport, the installation when it FINALLY happens is a joke. Also the quality of the metal and welds is what I consider marginal.
Here is ours that we finished covering with metal from a local supplier.
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
Old 02-18-2016, 08:15 PM   #12
Usually Confused Member
emm-dee's Avatar
Originally Posted by myezlife View Post
I'm thinking of getting a Carolina Carport for my TT. The height is 11'1" with A/C. The length is 29'. I'm looking at a 18X36X10. Do you think this would fit? Can anyone show pictures of what their comparable TT looks like in heir carport? Thanks.
Where are you located?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 02-18-2016, 08:39 PM   #13
Wobbles's Avatar
Briorick,
Please post any contact info you may have and re-state dimensions with price, so I have a reference point. PM if you do not want to post openly.
I have been looking real hard and just do not know where to begin. Spooky stuff when you have no experience.
Thanks.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 02-18-2016, 10:11 PM   #14
Briorick's Avatar
Originally Posted by Wobbles View Post
Briorick,
Thanks.
Hey Bob,
Here is the information for you. Maybe sharing will help others to decide as well.
I purchased mine last July from S & K Carports from the Mount Vernon, Il. area, but you can use any "All Steel Carport Dealer" to order from.
I ordered the 18' wide x 21' long ( 20' with 1' overhang, 6" on each end ) x 9' legs. 5' legs are Standard height and I needed to order 4' extra for clearance. That added $200 to the original purchase price.
So the total cost for this setup was $1109.31 ( prices may vary a little by now ). And that's including 3 screw down anchors for ground contact on one side. They anchored the other side into the concrete pad the TT sits on. The Mobile Home anchors, as they are called, ARE NOT included in the price. But well worth the money. If I remember correctly for a set of 6 they are approx. $50 extra.
My TT measures 9'11" with A/C and therefore I have a graduation of 2'1" to rooftop center, equaling 12'. As you can see my TT sits off to the right and I have plenty of rooftop room. It was suggested to get the 18' wide because it has a wider roof span and therefore creates a taller center. Was the best advice ever.
You are welcome to come down and take a look at it when you get a chance. Would give you a better idea with a TT underneath / parked in it.
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 02-18-2016, 10:30 PM   #15
Wobbles's Avatar
Thanks for the heads up. I will start bothering the folks at "S & K Carports". That price is more like it. I was guessing between 3k to 4K for my needs prior to this. (Lowes not even considered anymore) LOL.
Bob & Michelle
2015 Grey Wolf 26BH
Old 02-18-2016, 11:13 PM   #16
emm-dee's Avatar
"Bothering" the folks is good for you if you are doing it in person. Think of them like a car dealer...they want to sell you something before you get out the door and they'll probably negotiate. I worked direct with a local builder and was able to get my carport for $600 less than the Carolina Carport quote...and construction started 7 days after I placed the order.
Your current TT is 10.5 feet high. Your next one might be higher than that. A little extra height, etc., doesn't cost a whole lot more. I got a 20x40 with 11 foot legs (over 14' high in the center) for a final installed price of $2,900 (CC price was over $3,500).
Old 02-18-2016, 11:33 PM   #17
Briorick's Avatar
Excellent Point, emm-dee! Something that people should definitely ponder for future upgrades considering the temptations out there.
ALTHOUGH, for us, we purposely have the Carport dimensions we have. This is what keeps us from getting TOO big. Keeps us modest! ( Hmmm, on the other hand, I could lengthen the legs )
Rick & Brian
Old 02-19-2016, 04:42 AM   #18
We compared product options, price, and warranty between Carolina Carports and Bennett Building Systems. Assuming everything else was equal between the two companies including price, Bennett was the real winner and got our business on the basis of their warranty.
Carolina offers a 30 day limited warranty: 14 gauge units come with a 30-day limited workmanship warranty. 12 gauge carports come with a 20-year warranty against rust through on the frame, assuming normal care and maintenance and the 30-day limited workmanship warranty.
Bennett offers: 10 Year Limited Warranty On all Panels for material defects. 12 Month Workmanship Guarantee. If for any reason you are dissatisfied with the quality of the construction, anchors, welding, attachment, or any other aspect of your steel building within the first 12 months of ownership, Bennett Building Systems will rectify the problem at no cost to you. 20 Year Rust-through warranty on all steel tubing used to support your structure.
We talked to the local Carolina dealer and really wanted to do business with them because we talked to them several times and they were closer to us. After talking to Bennett we went back to Carolina to see if they could match the Bennett warranty. They could not. We placed an order with Bennett for a 24' wide x 31' long x 10' leg height. We added panels to both sides down to 2&1/2' above the ground with a fully framed and covered back.
2016 Micro Lite 25DKS, 2015 F250 6.2l Lariat 4x4 3.73's
rmillermtsu is offline   Reply With Quote
Old 02-19-2016, 08:10 AM   #19
WaltCole's Avatar
Update on my Elephant Structure Carport. Ordered over the phone 2/11/16. Just received a call from them this morning 2/19/16 to schedule my install for Tuesday morning 2/23/16. I will post update when delivered and installed with pic's.
2014 Ram 2500 4x4 Tradesman
2015 Forest River Heritage Glen 302FK
WaltCole is offline   Reply With Quote
Old 02-20-2016, 07:43 AM   #20
Homebrew's Avatar
Just noticed on line that Elephant structures are part of Carolina Carports. Is this true ???
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
