Old 03-03-2013, 06:37 AM   #1
Under carriage RUST
New 2013 Minilite that has rust areas on the frame. I want to know if anyone else has had this problem. If so what was the treatment used to rectify problem. Thanks for info. Electraglideblue
electraglideblue is offline   Reply With Quote
Old 03-03-2013, 07:53 AM   #2
Dave_Monica's Avatar
You need to keep the under-carriage clean and painted. I'm under the camper at least once every year touching up any areas that I find with black Rustoleum paint.
others have also suggested spray on undercoating which I may try in some areas this year.
Dave
Old 03-03-2013, 08:36 AM   #3
RV Newbie
buzzards27's Avatar
I use Rust Reformer. Seems to work well at stopping light surface rust in its tracks.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 03-08-2013, 12:44 AM   #4
I have heard good things about POR 15. It is supposed to be an apply it once and done thing. You can get it at most good auto parts stores or summit racing. Once the weather breaks I'm using it to do the underside of the truck and tt. It is supposed to go on right over the rust and kills it by sealing it in.
2008 Rockwood 8318SS
2012 Ram 2500 Crew Cab Diesel
Equalizer Hitch
KDEL1970 is offline   Reply With Quote
Old 03-08-2013, 09:22 AM   #5
Experienced Newbie
My 2012 Apex 151RBX was rusty the day I picked it up (early February 2012). It was due to poor welding and poor prep. Took it back to have the water tank supports welded properly and the frame repainted.
I have also heard good things about POR15.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 03-08-2013, 02:17 PM   #6
POR info says 1 qt will cover 96 sq ft for 1 coat. They suggest 2 coats for maximum result. I saw it for $47.50 a qt. I personally don't have that kind of exposed square footage underneath. Just two rusty axles and some frame.
Equalizer Hitch
