Originally Posted by Iwannacamp
Usually I think they are a hex head rivet shot from some tool. They have a rubber/plastic star shaped head. That piece will come off with needle nose pliers and then use a 1/4” hex to twist and pry out pin. Replace with self tapping or sheet metal screws with fender washers. Ymmv
Yes... most of the ones I've seen that are riveted use a fastener similar to this...
And the OP is right... they are often 'shot' in from the top before the floor is laid on the frame during assembly.
There is a video of this process somewhere. If I can find, I'll edit,
