07-16-2015, 07:37 PM
Vinyl trim molding screw covers
We have a 2013 Forest River 264L Cherokee TT. The white vinyl trim molding screw covers, located vertically on both front corners and horizontally across the back near the rubber roof, is cracking. Our dealer has gone out of business. We bought an extended warranty through our dealer that is honored at other authorized dealers for repairs. I checked at another dealer about bringing it in for these repairs and was told this is not a warranty issue. He told me that I could change it myself. I'm kind of handy, but I want it done right because I know it is important. I see that there are different width moldings on the market. What size do I need for my TT? Is this something that I should just take to a dealer for repair? And lastly, is this really not a warranted item?
Thanks.
2013 Cherokee 264L
2016 Ford F-250
FX4 Off-Road Package
10,000# GVWR Package
Towing Package
Chrome Package
07-16-2015, 07:58 PM
Hi,
I replaced the vinyl screw covers on my old trailer. The replacement is really easy as long as you get the correct size.You need to measure fron edge to edge of the track or old material. The material comes flat in a roll but is convex when installed. I also removed each screw one at time that was behind the vinyl screw cover. After removing one screw at a time, you might see like I did, some were rusted which indicates water infiltration. I pumped each screw hole with Decor sealant and reinstalled the screw to stop the water infiltration.
I would not say it is a warranty issue but more of a owner maintenance issue.
crunchman
2015 F-250 FX4
07-18-2015, 01:00 PM
Thank you!
2013 Cherokee 264L
2016 Ford F-250
Towing Package
Chrome Package
07-18-2015, 08:07 PM
No problem, hope it works for you.
crunchman
2015 F-250 FX4
07-19-2015, 03:37 PM
Agree with everyone else; it is very easy to do yourself.
VMI'62
07-19-2015, 03:49 PM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-20-2015, 06:53 AM
i had to do the same so i went online at Ebay found some contacted the seller they sent me several different styles to compare and chose from i found some that is actually a little heavier that looks like it will with stand time better but easy to install
good luck
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
07-20-2015, 07:17 AM
At the (Amana Rally) last year a Member had a (1) year old (Windjammer) and I was looking at his Trim Insert like you are talking about on the Street side! The Insert Vinyl on ! side Only was (Cracked Every 1") it looked like it was made that way! He had never noticed it? He did take it in for replacement! Youroo!!
07-20-2015, 09:05 AM
Thanks everyone for responding. I bought the vinyl trim and sealant and did the entire job in less than an hour this past weekend.
2013 Cherokee 264L
2016 Ford F-250
Towing Package
Chrome Package
07-20-2015, 04:18 PM
Did you pull the screws and put sealant in the holes? Were any screws rusted? Glad you got it done.
crunchman
2015 F-250 FX4
07-20-2015, 05:37 PM
I did not pull the screws out. They were not rusted. The vinyl moldings had just recently begun to crack. There was no damage found upon inspection.
Thanks for the help.
2013 Cherokee 264L
2016 Ford F-250
Towing Package
Chrome Package
07-20-2015, 09:58 PM
That is good to hear you got it buttoned up without damage.
crunchman
2015 F-250 FX4
07-21-2015, 07:33 AM
Too late I guess,,, but remember it is Vinyl,,, and it will shrink !!!
Ours on our Sunseeker shrunk,,, now the paint lines no longer match @ the front corner !!!
