Old 06-27-2008, 07:26 PM   #1
walk on roof
I have 2003 Cherokee lite 25w am i able to get on the roof for cleaning, ac maint, etc it does not have a ladder so was just wondering thanks
maverick54 is offline   Reply With Quote
Old 06-27-2008, 07:42 PM   #2
NO JUMPING JACKS!!!!
other than that sure. just don't go stomping on it. RV roofs should be plenty strong enough to support a 250lb person. if you are extra concerned you can use small 2x2 sections of half inch plywood to help distribute the weight
aintgotnun is offline   Reply With Quote
Old 06-27-2008, 08:22 PM   #3
I go up on my Flagstaff 26RKS all the time to clean it and to seal areas as needed. As Greg said, don't do jumping jacks or hold a dance up there, but normal walking will be fine.
Hokiehall is offline   Reply With Quote
Old 06-28-2008, 06:06 AM   #4
spepi's Avatar
I always wear sneakers or something that is flat. no heals like in a work boot or hiking shoe. and walk softly....your not on the ground, so sometimes you may feel a little give, and your heal may dent in a little. as long as the rubber doesnt tear, your good to go.
DW, 2 Teen's, 2 Dogs
2006 Chevy Suburban
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Control
2008 Rockwood 2701ss
Mansfield, MA
spepi is offline   Reply With Quote
Old 06-28-2008, 06:25 AM   #5
KyDan's Avatar
Wear tennis shoes.
Foam flip flops are slippery as sh-- well slippery as you know what when
wet.
I also suggest putting down your stabilizer jacks!!
I clean mine every season with simple green and water. I use a mop
so I don't have to get on my knees for most of it and do the tight places
with a sponge.
Simple green is kinda slippery so I try to rinse an area before I step on it.
I -think- getting that grunge off there helps not to have black streaks
on the sides as bad but we still get them ;-(
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
