Old 09-04-2013, 12:13 PM   #1
2Barnetts's Avatar
Washing & Waxing?
We just got back from our first trip in our new Windjammer. Any suggestions on the best way to wash & wax the exterior. What about the roof? Any product suggestions? Thanks in advance!
2Barnetts is offline   Reply With Quote
Old 09-04-2013, 12:37 PM   #2
Lynkage's Avatar
Just a good soap and water on the roof. Do not use Dawn on the roof if you have an exterior protectant on the fiberglass.
Otherwise I use a long adjustable pole with a brush on the end from Mr. Longarm.
Mr.LongArm Hydrasoar Flow Through Extension Pole Pole
Mr.LongArm Inc. Manufacturer of Quality Extension Poles
and a window cleaning bucket Unger 6 gal. Heavy Duty Rectangular Window Cleaning Bucket-DB02 at The Home Depot
and this soap. http://www.meguiars.com/en/automotiv...mate-wash-wax/
Also just a brush on the roof with a mild soap and just keep it clean and it will last a full lifetime of the roof 10-15 years +.
Waxing will prove to be much harder so use a good marine wipe on wax and do small areas at a time and make sure you do not have the surfaces hot or it will be very hard to get the wax off when buffing.
If power buffing be very carfull to use the right pad and DO NOT burn through the to the fiberglass as that will be permanent!
A really good waxing 1-2 times per year will keep the exterior in pristine condition.
Somewhere Turbs had a good write up on how to clean the roof and why you should.
Oh BTW start at the top and work down!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 09-04-2013, 12:47 PM   #3
2Barnetts's Avatar
Thank you very much!
Old 09-04-2013, 01:28 PM   #4
Steve Jackson
sideout1961's Avatar
Oh Crap! what happens if you use Dawn? I just used it on mine. Some people on here suggested using dawn as long as I rinse the sides right away.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 09-04-2013, 01:39 PM   #5
Send a message via MSN to Tiggerdad
Likely that Dawn will remove some/all of the wax on the sides that it contacts. Difficult to keep the sides wet down enough. You will do no harms but may have to touch up some areas.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 09-04-2013, 02:36 PM   #6
Lynkage's Avatar
It would be just like Tiggerdad said and would be instantly removed. Not a huge deal just need to be re-applied or waxed. Which ever protection you have.
Dawn is very good at removing grease\oil from surfaces. You could use it at the end of the year BEFORE the year-end wax!
Shane & Antoinette
Old 09-06-2013, 04:57 AM   #7
Send a message via MSN to Monterra
I'm wondering if one could use a power washer and the soap/wax mix that I use on the TV. That seems to cut the road grime quite effectively.
Good judgement comes from experience........
Experience comes from bad judgement!!!!
'10 2304 Mini Lite
'14 Honda Ridgeline
Monterra is offline   Reply With Quote
Old 09-06-2013, 11:18 AM   #8
I would not use a power washer on my fiver. I also would not use a power washer on my pickup.
whj77372 is offline   Reply With Quote
Old 09-06-2013, 11:29 AM   #9
Arefbee's Avatar
Power washer could blow the caulk out of seams making it a lot more project than necessary.
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 09-06-2013, 11:30 AM   #10
Golflover's Avatar
Unless you plan and repainting....
___________________________
2013 Crusader 260RLD
2012 Silverado LTZ
Nights Camped 2013 - 54 (54 scheduled)
Nights Camped 2014 38
Golflover is offline   Reply With Quote
Old 09-06-2013, 11:30 AM   #11
Ripley711's Avatar
I do not have a fiberglass trailer, I have a metal sided TT. I used Ibiz IBIZ World Class Wax the day we brought the new trailer home. They have a special wash mixture to use and then you apply the wax. It goes on easy and you wipe it off while still wet. I was able to do a 26ft TT in about 3 hours, done. For spot cleaning inbetween washes they have a waterless wash/wax the buffs the unit back to clean. This product is endorsed by the Covette Club of America and the Antique Auto Club. I would not use anything else now.
2012 Ram 2500 Larame Cummins
2018 Rockwood 8299BS
2014 Salem Cruise Lite 261BHXL (Sold)
2016 Camping Nights = 32
2017 Camping Nights = 14
Ripley711 is offline   Reply With Quote
Old 09-06-2013, 05:25 PM   #12
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Just finished after two days cleaning and conditioning the roof and washing and waxing the 5er. I was on a roll so I washed and waxed the truck too. It sure looks pretty!!! Here's what I used. All purchased at Camping World.
Cleaning the roof; Thetford Premium Rubber Roof Cleaner
Conditioning the roof; Dicor Roof-Gard
Washing; Gel Gloss Heavy Duty RV Wash and Wax
Waxing; Gel Gloss Heavy Duty RV Cleaner and Wax
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 09-06-2013, 05:36 PM   #13
2Barnetts's Avatar
Thanks you!
wax
