02-10-2017, 06:04 PM
Washing roof
What is recommended for cleaning your roof. I purchased back in June 5th, 2016. I have detailed everything else but not the roof. What is the recomendation. & if you say soap and water what do you seal with as far as your UV rating?
Tim Coltrain In NC
Tim & Rita Coltrain
2021 Chevrolet 3500 Duramax Crew Cab, Allison Tranny.
XLR Thunderbolt 2016
02-10-2017, 06:11 PM
Lots of threads on cleaning roof, but many people use dawn to clean and Aerospace 303 to treat. You can also buy commercial cleaners at any RV dealer/store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-11-2017, 11:20 AM
Cleaning Roof Found This
Ok, I got up this morning to wash roof of camper. The weather is in my favor today. Suppose to be 70 degrees. When its around 50 or better I'm happy. I followed instruction with mild soap and water followed by rinsing. I found these and wanted to know is this normal. Here are four pictures. Now remember I bought this back in June 2016. So give me your opinion.
Tim Coltrain in Warm NC In February. Weird Weather.
Tim & Rita Coltrain
02-11-2017, 01:00 PM
To me that's not normal. The mildew line is too straight for too long. I've had 3 fifth wheels now, and while my tops were pretty dirty because of the trees I've never seen a straight line like this after washing. It almost seems to be like moisture under there that feeds the mildew, or maybe there's a ridge that holds the dirt in like that. Weird. But I also see it over every roof rafter.
02-11-2017, 01:07 PM
I'm going with Dawn, and maybe a sealant. I've researched recommended cleaners, and all point to dawn as the most effective yet gentle products out there. For lots and lots of different uses. Not any other is mentioned. As far as sealant for the roof material I wonder how effective that is overall. I've not been overly impressed by the cleaners from the rv store, especially for the price.
02-11-2017, 01:23 PM
Left Coast
303 and Dawn
02-11-2017, 01:35 PM
Washing roof
Looks to me those lines are the seams where the roof panel come together. Probably just a slight dip where your big brush did not get to. Try some dawn and a smaller brush. Or toothbrush and see if it comes off. Almost looks like they are 4ft apart.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
02-11-2017, 01:36 PM
Left Coast
I do mine on knees....
02-11-2017, 02:24 PM
Forrest River
I sent Forrest River an email this morning to see how they respond. I could understand spotting but every four foot there is a straight line and then on the front at the head there is a perfect 12 line all the way across. Something's going on here.
Tim Coltrain
Tim & Rita Coltrain
02-11-2017, 03:07 PM
The interior layer of a rubber roof is black. What you could be seeing is the outer white ( surface) layer is gone exposing the interior black layer which appears to be crumbling. If so that is not normal for a new or good condition roof. I would expect to see that on an old worn out rubber roof that was ignored. I would definitely get that to the dealer.
TST Tire Monitors
2 100W solar panels
02-18-2017, 11:16 AM
Finished Product
Completed: For Starters
1. Dawn and Water with car brush
+ Cleaned Some but not much
2. Sprayed with Bleach
- Didn't work
3. Tire Beach & Soft Brass Brissel Brush
+/- That worked at 75%
4. Pressure Washed
+ Help some more 15%
5. Left with about 10% black spotting
6 .Treated with UV ray protectant roll on with paint roller.
Tim Coltrain In Winterville NC
You be the judge, After all that several people told me just deal with it and I can't stop it.
I Tried at least
Tim & Rita Coltrain
02-18-2017, 11:54 AM
Left Coast
A little more often might help.....and a stiffer brush
02-19-2017, 12:22 PM
This product works for me. Follow up with the treatment solution made by the same company. I used to use Dawn, but noticed roof was becoming dingy after several years. This product made the roof look like new! Easy to use also with no chemicals to run down the side of your rig leaving streaks.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
