Old 02-10-2017, 06:04 PM   #1
Tim Coltrain's Avatar
Washing roof
What is recommended for cleaning your roof. I purchased back in June 5th, 2016. I have detailed everything else but not the roof. What is the recomendation. & if you say soap and water what do you seal with as far as your UV rating?
Tim Coltrain In NC
Tim & Rita Coltrain
2012 Chevrolet 2500 Duramax Crew Cab, Allison Tranny Has now been replaced by a NEW 2018 LP5 Duramax 2500 Allison Tranny.
XLR Thunderbolt 2016
Tim Coltrain is offline   Reply With Quote
Old 02-10-2017, 06:11 PM   #2
Flybob's Avatar
Lots of threads on cleaning roof, but many people use dawn to clean and Aerospace 303 to treat. You can also buy commercial cleaners at any RV dealer/store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-11-2017, 11:20 AM   #3
Cleaning Roof Found This
Ok, I got up this morning to wash roof of camper. The weather is in my favor today. Suppose to be 70 degrees. When its around 50 or better I'm happy. I followed instruction with mild soap and water followed by rinsing. I found these and wanted to know is this normal. Here are four pictures. Now remember I bought this back in June 2016. So give me your opinion.
Tim Coltrain in Warm NC In February. Weird Weather.
ID:	129573   Click image for larger version
ID:	129574   Click image for larger version
ID:	129575   Click image for larger version
Tim & Rita Coltrain
Old 02-11-2017, 01:00 PM   #4
To me that's not normal. The mildew line is too straight for too long. I've had 3 fifth wheels now, and while my tops were pretty dirty because of the trees I've never seen a straight line like this after washing. It almost seems to be like moisture under there that feeds the mildew, or maybe there's a ridge that holds the dirt in like that. Weird. But I also see it over every roof rafter.
Mdaniels4 is offline   Reply With Quote
Old 02-11-2017, 01:07 PM   #5
I'm going with Dawn, and maybe a sealant. I've researched recommended cleaners, and all point to dawn as the most effective yet gentle products out there. For lots and lots of different uses. Not any other is mentioned. As far as sealant for the roof material I wonder how effective that is overall. I've not been overly impressed by the cleaners from the rv store, especially for the price.
Old 02-11-2017, 01:23 PM   #6
Left Coast
303 and Dawn
Old 02-11-2017, 01:35 PM   #7
rmac04401's Avatar
Washing roof
Looks to me those lines are the seams where the roof panel come together. Probably just a slight dip where your big brush did not get to. Try some dawn and a smaller brush. Or toothbrush and see if it comes off. Almost looks like they are 4ft apart.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 02-11-2017, 01:36 PM   #8
Left Coast
I do mine on knees....
Old 02-11-2017, 02:24 PM   #9
Forrest River
I sent Forrest River an email this morning to see how they respond. I could understand spotting but every four foot there is a straight line and then on the front at the head there is a perfect 12 line all the way across. Something's going on here.
Tim Coltrain
Tim & Rita Coltrain
Old 02-11-2017, 03:07 PM   #10
Flybob's Avatar
The interior layer of a rubber roof is black. What you could be seeing is the outer white ( surface) layer is gone exposing the interior black layer which appears to be crumbling. If so that is not normal for a new or good condition roof. I would expect to see that on an old worn out rubber roof that was ignored. I would definitely get that to the dealer.
TST Tire Monitors
2 100W solar panels
Old 02-18-2017, 11:16 AM   #11
Finished Product
Completed: For Starters
1. Dawn and Water with car brush
+ Cleaned Some but not much
2. Sprayed with Bleach
- Didn't work
3. Tire Beach & Soft Brass Brissel Brush
+/- That worked at 75%
4. Pressure Washed
+ Help some more 15%
5. Left with about 10% black spotting
6 .Treated with UV ray protectant roll on with paint roller.
Tim Coltrain In Winterville NC
You be the judge, After all that several people told me just deal with it and I can't stop it.
I Tried at least
ID:	130128   Click image for larger version
ID:	130129   Click image for larger version
ID:	130130   Click image for larger version
ID:	130131   Click image for larger version
Tim & Rita Coltrain
Old 02-18-2017, 11:54 AM   #12
Left Coast
A little more often might help.....and a stiffer brush
Old 02-19-2017, 12:22 PM   #13
NMWildcat's Avatar
This product works for me. Follow up with the treatment solution made by the same company. I used to use Dawn, but noticed roof was becoming dingy after several years. This product made the roof look like new! Easy to use also with no chemicals to run down the side of your rig leaving streaks.
ID:	130194   Click image for larger version
Scott and Liz - Southern NM
roo, roof
