Old 11-15-2015, 02:31 PM   #1
Water damage...how do I fix this?
I found a gap in the caulk around the rear baggage door on my 2014 3100ss...figured I could scrape the old stuff off and re-seal. Took the door off and found the whole bottom sill and a good portion of one of the side sills are soaked. The gel coat skin is loose from the structure. Obviously first step is to let it dry out, but what should I use to re-attach the skin to the structure?
ID:	94370   Click image for larger version
rad_jr is offline   Reply With Quote
Old 11-15-2015, 03:03 PM   #2
Mike968's Avatar
I wonder if you could use a rubber cement and clamp it until it cures? If it's a big enough gap, 3M spray adhesive might be a good option. Whatever you use I would think it would have to be water proof.
Mike968 is offline   Reply With Quote
water
