water damage under rubber roof
I just discovered a small hole in a repair of a torn rubber roof, The wood seams to be a small 10" wide and 24" long like a rectangle piece. Can I successfully repair by lifting the robber up removing the OSB replacing and regulating the rubber roof back?
Or do I need to just remove the remove the entire rubber roof and prplace the damaged area and put new rubber membrane ?
