Old 07-01-2016, 05:09 PM   #11
Awning seam leak
Originally Posted by Lowes48fan1 View Post
Teamfour--how do you plan on sealing the seam in the gutter? Would latex caulk work or lapseal? Anything that has much of a profile will cause water to flow over the edge of the rain gutter.
On my trailer gutter there is a seam on each side. And on each side it leaked. Both had caulk which cracked. There was a small gap where the two pieces of gutter met. I cleaned the caulk out, sprayed a rag with Eterna Clean to clean out well and then cut a small piece of Eternabond to fit into the seam. The tape covers the bottom and sides of the gutter. Smoothed it out snug against the track and then applied a smooth application of Dicor to the edge. (Keep the caulk very thin so as not to impede the water flow). All of this was done from the roof side (inside gutter). So far, so good.
wildwoodtraveler is offline   Reply With Quote
awning, leak, water, water leak
