Old 11-12-2012, 08:04 PM   #1
Water leaking around trim on outside kitchen
Hello all,
I have a LaCrosse 319 and we have a small water(rain) leak around the trim on the large swing up compartment door... the rain runs down the outside of the compartment door and then down in behind the trim and drips into the jam of the compartment door... It does not leak into any area of the inside of the camper, the water just lays in the jam and when you raise the compartment door the water drips from the latch/ trim at the bottom of the compartment door... What do I need to do to seal up this door caulk, or take door apart and seal that way? Help please... Thanks Joe.
ky joe is offline   Reply With Quote
Old 11-12-2012, 08:51 PM   #2
Dave_Monica's Avatar
Sounds like the door seal isn't doing it's job. Is the camper still under warranty?
Dave
Old 11-13-2012, 07:23 AM   #3
yes still under warranty... what type of seal is used around the fiberglass to metal trim on the compartment door?
