Old 07-24-2013, 11:14 AM   #1
water leaking from ac vent
After a hard rain the ac vent infront ot dinett leakes on to floor. No other vent leaks. Any ideas on this problem????
stonetail is offline   Reply With Quote
Old 07-24-2013, 11:53 AM   #2
Please tell us what RV you have. (It's best to put that into your profile and/or signature so it's always available.)
Old 07-24-2013, 07:33 PM   #3
ac leaking
i have a salem 28ddc 2010 3 rd time i used it
Old 07-24-2013, 07:57 PM   #4
realebill's Avatar
i had a leak from my ac vent in the bedroom on my rockwood 8315SS after a hard rain. thoroughly checked all the seams and eternabond tape around all the roof vents,ac ,skylight and frig vent. finally found the source of the leak....water was seeping into the screwholes on the side trim at the top of the side.see attached pic of my neighbors trailer,(he had the same problem) we replaced all the screws with stainless steel,put sealant on them before we screwed them back in and made sure they were tightened to pull the trim tight against the side.
i have not had any leaks since the repair.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 07-24-2013, 09:40 PM   #5
Albuquerque, NM
Char_n_Kath's Avatar
We had a water leak after hard rain in our Rockwood when it was just past one year old -i.e. about one month out of warranty! Turned out to be the bolts holding down the unit had loosened up, which are accessed from inside. The dealer tightened these without charge & I've had no problems since.
Charlie & Kathi
Albuquerque, New Mexico
2011 Rockwood 2304
2013 Dodge Ram Laramie 4x4
Char_n_Kath is offline   Reply With Quote
