Old 04-30-2015, 08:36 PM   #1
Wax question.
We've just purchased a used 5th wheel and I've been reading that trailer should be waxed a couple of times a year. Can I use spray wax with my pressure washer?
larryo is offline   Reply With Quote
Old 04-30-2015, 08:53 PM   #2
WFD
I would be careful with a pressure washer on an RV...it can be hard on your decals and there are alot of nook and crannies that you may not want moisture being driven into, and it can be hard on your caulking. I quit using my pressure washer on our 5th. Now just use a hose and a brush.
As far as wax goes, I think you will get better results with waxes that you apply by hand and remove by hand. Some of the spray type waxes work well also, and are alot easier and quicker, making it easier to do more often or in between the more labor intensive wax applications.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-30-2015, 09:07 PM   #3
I just tried out some wax made by Turtle Wax.Called spray Ice.Worked super easy.Spray on polish off.Did the 5er last week and it removed some bugs that were on there from last falls trip to the west coast.Nothing else would budge them. Did the truck this weekend and man what a shine.
DaveandSue is offline   Reply With Quote
Old 05-10-2015, 06:14 PM   #4
I use the Ice on my RV and boat in between normal waxing. Works great and the more you do it the more the protection and shine comes out.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 05-10-2015, 06:25 PM   #5
Flybob's Avatar
I have been using Meguiar's G12718 NXT it is easy to use and wipes off very easily. You can leave it on for hours and still get it off. It actually works better if it sits a while. Shines nicely and bugs and dirt clean off easily.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-10-2015, 06:51 PM   #6
Thumbs up
^^^what he said
2015 Forest River MicroLite 25 DKS
Jimmyw is offline   Reply With Quote
Old 05-11-2015, 07:39 PM   #7
Randoon's Avatar
http://cdn3.bigcommerce.com/s-v23zx/...0.1280.jpg?c=2
This is the best wax I've ever used. One bottle will do 30' fiver and the tow vehicle. Goes on easy, can do entire unit before taking off. No residue. Sons and neighbors have tried it and love it. If link doesn't work, it's Lane's Car Care Products, Ellisville, MO
Randoon is offline   Reply With Quote
Old 05-11-2015, 08:02 PM   #8
Boss Hoss's Avatar
Meguire's Marine Wax-made for boats.Put it on with an orbital-and off by hand.
I've got 3 coats on my trailer.It's pricy-$32 per quart but worth it.
It was so good I put it on my F150 too.
Work worth doing-I learned about it on this board.
You won't go wrong with is if you have a smooth sided rig.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 05-11-2015, 09:54 PM   #9
mud yapster's Avatar
Thanks for the wax advice I haven't been to pleased with the last wax product I used. Going to try the Protectall stuff this time.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
wax
