Old 08-19-2018, 03:29 PM   #1
What did I do wrong?
So I installed some Camco cyclone RV tank vents two weeks ago. Was a fairly basic install (I thought).
Well I just went up on my roof to check on things and noticed that the lap sealant didnít hold up on the plastic. What did I do wrong and what do you recommend for the best way of fixing it? Think I am going to pull it all up and redo it again but I have to order more lap sealant.
The first picture is after I installed the vents. The next two are what it currently looks like. The last picture is the product I used.
Just to give you a little more info. The RV stays at a campground full time. I noticed this right before I left so I took some 100% silicone and put it on to keep out any water until I can properly fix it.
ID:	183733   Click image for larger version
ID:	183734   Click image for larger version
ID:	183735   Click image for larger version
NLaudy is offline   Reply With Quote
Old 08-19-2018, 03:31 PM   #2
did you clean first ? need to wipe down with acyetone before applying sealant . roof was dirty so it didn't stick
MR.M is offline   Reply With Quote
Old 08-19-2018, 04:13 PM   #3
Yeah I cleaned it first but it wasnít really the roof where it didnít stick. It didnít stick to the vent itself and the cover. Thanks for the assistance.
Old 08-19-2018, 04:21 PM   #4
Flybob's Avatar
I would clean and scuff up the flange. If there is mold release on the flange, it will not stick.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-20-2018, 12:01 AM   #5
Splitshaft's Avatar
Well, maybe you did not do anything wrong if everything was well cleaned of any wax, oil, or grease. I always use Dicor non-leveling 551 lap sealant for that kind of work instead of their 501 product. To each their own.
Splitshaft is offline   Reply With Quote
Old 08-20-2018, 12:37 AM   #6
Yep, that's the stuff that's needed here.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-20-2018, 09:38 AM   #7
grumpy0374's Avatar
Well I just went up on my roof to check on things and noticed that the lap sealant didn’t hold up on the plastic. What did I do wrong and what do you recommend for the best way of fixing it? Think I am going to pull it all up and redo it again but I have to order more lap sealant.
Before you try to reseal it, you'll have to pull the vent out and clean it thoroughly. You stated you used silicone to temp seal it, and now, nothing will adhear to it unless ALL traces of silicone are removed. Even new silicone will not stick. Any Dicor will simply fall off.
grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 08-20-2018, 12:14 PM   #8
grumpy
Thank you everyone for the input!
Grumpy, thanks i wasnít aware of that. Just to be safe after removing all the silicone and Dicor I will rough up the vent with sandpaper also!
Old 08-20-2018, 04:00 PM   #9
I don't think you need to remove everything you've done. In the pics it looks as if the dicor adhered to the roof just fine. You're only problem is it didn't adhere to the vent plate for a complete seal. I'd just clean and rough up the roof vent plate and then put eternabond tape over it and the dicor.
2016 RAM 2500 Laramie
SB 4x4 6.7L Cummins
Pullrite SuperGlide
2015 Palomino Columbus 320RS
ICanFixIt is offline   Reply With Quote
Old 08-20-2018, 06:23 PM   #10
gooiebob's Avatar
Looks like you used self leveling Dicor. You need the regular Dicor that doesn't self level. You could apply it right over what you have already done.
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
