Old 08-02-2016, 01:05 PM   #1
NYDP77's Avatar
What does delamination feel like?
I think there may be a spot on my travel trailer where delamination may have occurred? However, I've never seen it in person and really don't know what it looks or feels like to the touch. Most pics I've seen online makes it look soft if you where to touch it. The section on my RV is on the streetside right at the back of the camper, where it meets the back wall, and runs about 8 inches down the camper (the back wall is fine). It looks like a bulge and is hard like the rest of the fiberglass on that side, there are no tears in the fiberglass. Sorry for no pics, I will try to put up some when I'm back at my camper this weekend. It's a 2014 Tracer 240 AIR, I've only used it for 3 and a half seasons. All seals look good to me.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 08-02-2016, 01:15 PM   #2
Witch Doctor's Avatar
If you look at it sideways you should see a bubble, that's when the gel wall separates from the sheet of wood. You should be able to feel it, it won't be smooth anymore. hope that helps... hope not...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-02-2016, 01:24 PM   #3
Most delamination is a bulge.
It could maybe be described as 'soft' if you are able to push on the bubble and it gives some where the outer fiberglass skin pulls away from the under layer.
With that said, I've seen some imperfections in the side walls where it was bulged from a wood chip being under the skin prior to lamination or where the aluminum framing wasn't perfectly level. While it looked bulged, it wasn't delaminated.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-02-2016, 01:50 PM   #4
It is true what you posted, I do take issue with the part of something in between from construction. If there was an area even 1x1 and it was sticking up, that means there is no bond between the skins. That is still delamination no matter what caused it to separate. Simply put delamination is the separation between layers....
Old 08-08-2016, 06:58 AM   #5
TandSH's Avatar
Tap Test
It is easy to determine if there is any delamination and the extent of any that may exist with a tap test. Use a coin about the size of a quarter and tap the surface. If the laminate is good the sound of the tapping will be like what you would hear when tapping on a pane of glass or solid surface counter top. If there is any delamination you will hear a very different, dull sound.
2017.5 Cedar Creek 34RL2
2016 Flagstaff 8528IKWS Diamond Pkg (For Sale)
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
delamination
