Old 10-13-2011, 10:24 PM   #11
sherdep's Avatar
Dicor Self Leveling Lap Sealant.
I agree that any visible cracks should be re-caulked with the Lap Sealant to prevent any leaks
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-16-2011, 04:13 PM   #12
I have seen the recommendation to use acetone to clean, but Alpha Systems, the maker of my TPO roof, specifically states to NOT use acetone on the membrane:
http://www.alphasystemsinc.com/files...structions.doc
I suppose one could argue to use it on the caulk and keep it off of the membrane, but I don't think I could split hairs that well.
Any comments on this?
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
K_and_I is offline   Reply With Quote
Old 10-16-2011, 05:01 PM   #13
BigDTx's Avatar
I would not use acetone it will make the membrane soft. Our insurance requires us to have the roof maintained yearly, clean/condition and inspected for leaks.
acetone is a pretty strong solvent for a rubber membrane IMO.
BigDTx is offline   Reply With Quote
Old 10-16-2011, 06:31 PM   #14
grhodes50's Avatar
I also was going by the recommendations I have read about using acetone. I haven't ever heard or read of any adverse effects of acetone on the roof membrane, but whatever you use you should be careful since these are strong solvents.
I guess I should have posted what I actually use. It's 3M Adhesive Cleaner that I purchased from my dealer. The way it smells it might as well be acetone. I've used it on two different tt's and my pop up. I was told to use it only where I would be caulking and I'm not so good that I keep it off the membrane completely, but I've never noticed any problems.
Gary & Trish
2018 Nights Camped - 5
Old 10-16-2011, 06:43 PM   #15
(Kim)
Labzy's Avatar
If we are careful and do no get any onto the membrane itself I think we will be safe, which makes me think that I will clean the caulking myself before I take it to get recaulked (if needed), so I can make sure of this.
Think I can use my nailpolish remover ???? It is mainly acetone............
JK
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-18-2011, 06:29 PM   #16
sherdep's Avatar
JK
Why take it to someone - if you decide to clean it and drive it somewhere most likely you will have bugs stuck to it
just caulk it - you will save a lot by doing it yourself
