Old 11-29-2016, 01:16 PM   #1
bob dirt's Avatar
What's the best roof repair caulk
It finally happened. My roof leaked and shorted out an LED above my cab-over bed. I found it because the light was on and would not shut off. I was just going in the run my heat on "heat pump" mode to see if it worked. I pulled the light from the ceiling and there was a small amount of water on it. I went up on the roof and it looks like water seeped through the caulking in the corner. Water was still standing...and a little bit of ice.
I did a search and don't really want to spend the day reading. I never went to the library as a kid.
My RV is still under warranty but not really wanting to let others work on it. A new light is about 20 bucks.
Just looking for a good solution before I go over to Al's RV and talk to a salesperson....thanks in advance
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 11-29-2016, 01:41 PM   #2
Eternabond tape for seams. Dicor Lap Seal for everything else horizontal. Dicor non lap seal foreverything verticle.
donniedu is offline   Reply With Quote
Old 11-29-2016, 01:55 PM   #3
bob dirt's Avatar
I've been reading about Dicor. Lots of people happy with it and some not so happy...just like every other product ever made. I don't think the tape is what I need for my one piece roof. I wish I could remember what I used for a 5er I had a while back. That stuff was really good.
Old 11-29-2016, 02:12 PM   #4
mikakuja's Avatar
Dicor lap sealant.
2017 Surveyor 245BHS
2011 F250 6.2L Crew SB 4X4
mikakuja is offline   Reply With Quote
Old 11-29-2016, 06:20 PM   #5
My neighbor basically recovered his entire roof with blackjack white that is compatible with the epdm rubber membrane. He had alot of issues on an older trailer. Eternabond tape, then dior lap, then the blackjack.
Mdaniels4 is offline   Reply With Quote
Old 11-29-2016, 06:25 PM   #6
Ford Idaho's Avatar
Kind of sure I would not want to peel that roof off....
Old 11-29-2016, 06:52 PM   #7
World Wide Wanderer
wahoonc's Avatar
Find out WHICH roof you have first. Eternabond is a good bet, that stuff will stick to any clean surface. We use a similar product for patching old commercial roofs to get the owners through until they can replace it.
Dicor is good, but make sure it is compatible with what you already have or you will create a bigger mess. I would contact FR for their exact recommendation.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 11-29-2016, 11:42 PM   #8
bob dirt's Avatar
I don't think Eternabond is what I want. I just need some sort of caulk (probably self leveling) to seal a small bad spot in the factory caulk on the edge of my one piece roof. Probably going to use Dicor self leveling.
I don't know how many different roofs FR has, but contacting them for information isn't on my radar. The company is no better than the person on the other end of the phone. Sorry...no faith in them or CW for repair problems. I got stupid answers when I called about my microwave coming loose and just about falling out...yeah, "just put in bigger screws"
Old 11-30-2016, 01:44 PM   #9
I did last year the roof repair with Eternabond and Dicor self leveling and did a good job but the rest of the roof cannot be clean, it is full of exidation.
I tried 2 different stuff that is recommanded for RV but not good for my epdm rubber membrane.
Desprit, I tryed to clean a small spot with acetone and it work but, it is not recommanded.
Anybody had experence with this stuff?
Jonol is offline   Reply With Quote
Old 11-30-2016, 02:55 PM   #10
Newly Retired
Steveboe's Avatar
I used to think that rubber roofs were the best thing ever but, they are only as good as the workmanship of the installers. Any seam between any strip or opening is subject to leak at some point. Its just to bad that the installers don't treat the job like their name is on it.
Can you tell that I found a couple of suspect looking areas on my 2016? Front corners where an ounce of water might sit, and "top to side" corners.
Steveboe is offline   Reply With Quote
Old 11-30-2016, 03:00 PM   #11
Bob dirt I used Dicor self leveling lap sealant on my roof and it did a really good job it is not going to leak if you clean the surface most dealers or Amazon will have a cleaner for RVs with rubber roof membrane. Acetone might work but it could make it worse . Remember that dicor is really sticky and will get every where if you aren't careful how you put it So keep a rag handy I used a little mineral spirits to get if off of any think it was not supposed to get on. including me.
cdog7201 is offline   Reply With Quote
Old 11-30-2016, 07:01 PM   #12
Canadian Member
Your roof is probably either EPDM (rubber) or TPO. The only other type would be aluminum. I don't know which one Forester uses on their MHs.
For EPDM, use Dicor's 501 self-levelling sealant in the greenish-yellow tube. For my TPO roof, I use Alpha Systems's self-levelling sealant.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 12-01-2016, 12:05 AM   #13
bob dirt's Avatar
My roof looks like fiberglass
Old 12-01-2016, 04:47 AM   #14
3m 5200 wins for me! Once it goes on, it's NEVER coming back off!
D-Man is offline   Reply With Quote
Old 12-01-2016, 06:56 AM   #15
Canadian Member
Oops. I completely forgot about Fiberglas. Dicor will work for Fiberglas. Check out YouTube videos by RV Geeks. They have a Fiberglas roof on their Class A MH.
https://www.youtube.com/user/RVgeeks
Old 12-01-2016, 11:18 AM   #16
Bobdirt roof sealant
the pop up I used to have had a fiberglass roof and was sealed with Dicor on it from the factory and when I rebuilt the roof rafter I used Dicor to seal the corner pieces and roof rail it works but you have to give it a day or two to cure before moving it.
Old 12-01-2016, 11:09 PM   #17
bob dirt's Avatar
Thanks for the help. I'll be looking for some Dicor self leveling tomorrow. Today was play day...I went riding
Old 12-01-2016, 11:59 PM   #18
Awesome. I'm a biker too. Ride to live. Live to ride.
Old 12-02-2016, 04:55 AM   #19
Cajun Style's Avatar
For cleaning rubber roof you could use denatured alcohol , I have an aluminum roof I used acetone.
For caulking my aluminum roof I used Dico C-10 self leveling, I also use the butyl tape 1in. Wide. Dico also makes a product for rubber roofs.
Harry-O
Cajun Style is offline   Reply With Quote
Old 12-02-2016, 05:02 AM   #20
DYCO is the correct spelling.
https://www.ebay.com/itm/131654962358
Harry-O
caulk, repair, roo, roof, roof repair
