Old 04-16-2019, 04:05 PM   #1
What's the big deal on not using silicone?
I've seen several posts over the last year with some going into shock at the suggestion of using silicone as a sealer on an RV. I'll be attaching some stuff to the exterior aluminum walls (starting with some door magnets) and won't risk leaks through the screw holes. I have a lot of carpentry experience and use silicone all the time on homes.
I suspect it may be rubber roof related. Or fiberglass?
2019 Cherokee Wolf Pup 16BHS
2008 Ford Explorer V6 w/tow package
Husky Centerline TS WDH 400-600# rated bars
2018 camped 16 nights at 4 GGs.
Boomerweps is offline   Reply With Quote
Old 04-16-2019, 04:29 PM   #2
Iwannacamp's Avatar
IMO I think there are two basic reasons to avoid RTV on an RV. 1. rubber roof products incompatible. 2. nothing else will stick to it when cured.
My RV(metal sided) has RTV all over the outside of it... I sticks well to metal and whatever... not plastic vents and the like.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Iwannacamp is online now   Reply With Quote
Old 04-16-2019, 04:29 PM   #3
Well.....for starters, if/when IT needs repair, nothing will stick to it, not even fresh silicone.....(so I've been told)
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 04-16-2019, 04:43 PM   #4
Trailer Park Supervisor
NJKris's Avatar
So it can't be scraped off? BTW, just mounted a kick ass outdoor speaker in place of original horrible speaker using screws and 3M marine adhesive. That thing ain't going NOWHERE! Or leaking.
NJKris is offline   Reply With Quote
Old 04-16-2019, 05:00 PM   #5
bob213's Avatar
Yes it can, but it's a PITA.
Next time try Lexel. It will stick to itself even after it's cured.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is online now   Reply With Quote
Old 04-16-2019, 05:04 PM   #6
Witch Doctor's Avatar
I wouldn't use it on a rubber roof, there use Dicor, but on the rest you can use it, the reason people don't even through I do is because you can't make anything stick to it after you apply it, you would have to remove the old first, that's the only reason, the factory gave me 2 clear tubes of it they used it on mine.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-16-2019, 09:20 PM   #7
SPRING IS COMING!!!
BriaBeck's Avatar
X2.
I replaced my outdoor speakers and installed/sealed them in with Lexel.
First time using it on an RV, but where I've used it before, it is superior. Good stuff!
Brian & Becky
__________________________________
2018 Avenger ATI 27RBS, pushing a 2002 Chevy Silverado 2500HD Duramax w/ Allison 1000
BriaBeck is online now   Reply With Quote
Old 04-16-2019, 09:28 PM   #8
X3.
Lexel is great stuff.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 04-17-2019, 05:29 AM   #9
jd50i's Avatar
For me, the biggest reason not to use silicone on my RV is it will make hardware rust.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 04-17-2019, 11:20 AM   #10
togo444's Avatar
Check out this guys YouTube channel. He will give multiple examples as to why silicone isnít a good idea on a vehicle that shakes violently. Itís called RVroof repair.com. I am not trying to advertise for him butís was mesmerized and horrified watching the slew of repairs that he made. Itís highly educational.
togo444 is offline   Reply With Quote
