Old 07-26-2016, 07:28 PM   #11
crunchman12001's Avatar
What did the insurance company say? How could they not help?
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
Old 07-26-2016, 11:34 PM   #12
lytlej's Avatar
Progressive never called back after I filed claim. They said within 2 days. I called them again Monday. They told me that all delamination comes from water damage and they don't cover water damage. I can't tell what was damage pre delamination and after the wind event. They are sending an inspector next Monday. We'll see.
I'm not feeling too strongly about my claim. So I'm starting to look at DIY ways to get me going again. I'll let ya'll know what Progressive says after next week.
lytlej is offline   Reply With Quote
Old 08-01-2016, 06:27 PM   #13
lytlej's Avatar
Well the Progressive inspector came today. He says he thinks it is from water damage, but will require an additional review. He felt it would not be covered.
Old 08-01-2016, 07:33 PM   #14
Witch Doctor's Avatar
I really don't understand their attitude. My roof delaminated the plywood under the rubber membrane. Had about a 12x12 square of plywood that the glue let go. Now I know and they know that it was water damage that caused the delamination. Granted in a storm in Florida a branch hit the roof and put a pin head hole in it or maybe the size of your little nail. I must have not been in the trailer at the time, or I should have heard it hit. So all the rain this year in Dec. and Jan. the rain got to it. I went to have the yearly maintenance done on it and the service company found it. I called my insurance which is AARP Hartford, they sent the estimator to my home, he looked at it and said the roof needs to be repaired from water damage. I said well I got two est. one to repair it back to the antenna. then one from FR to replace the whole roof. Hartford cleared the whole roof replacement saying that a patch can leak and cost them more down the line, so they put it under a comp and I had to pay 500.00 deductible. So now why is yours different? It was still delamination from water. Even if you leaked down the side there is really no difference, you don't know what hit it and caused the leak, you sealed it as I did when found, that's what they tell you to do. I wouldn't accept there answer. Probably won't help but maybe you can put that bug in there ear...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-01-2016, 11:53 PM   #15
lytlej's Avatar
Found some other issues as I pulled the edging off after they left. I'm going to try again with pleading my case as well as talk to Forest River as the leak was discovered just out of warranty. But I'm switching this to another thread to get advice about how to repair this mess.
Old 08-10-2016, 05:58 PM   #16
Wildwood 28DBUD side delamination due to wind
I had a similar issue coming home from the mountains last month. All was good (except for the wind) and then I noticed the side panel of the camper bulging out. I stopped and gorilla taped it as best as I could. It goes to the dealership tomorrow. I pray it is repaired under warranty. To date, I know of very little chance that mine is water damage. It has been stored inside. In my opinion, it should've held up better to the wind than it did.
ID:	116858   Click image for larger version
ID:	116859   Click image for larger version
jsverner is offline   Reply With Quote
Old 08-14-2016, 10:24 PM   #17
lytlej's Avatar
Wow. That's the same area mine delaminated. When I pulled the front edge trim, I could tell the edge was not sealed very well. I'm sure yours will be covered under warranty. Mine was a year and a half out of warranty.
Old 10-04-2016, 05:35 PM   #18
Austintatious's Avatar
Did you ever get this resolved?
This past weekend I noticed the same thing happening on the front driver side of my trailer whenever I got over 40mph. Apparently the wind blowing over that front section creates a low pressure area that "lifts" the siding out enough to pull the staples out of the wood. I've got some white low-profile panhead screws I was going to use because I figured even if the dealer pulled all the siding in that area and re-stapled it, it's bound to eventually happen again.
2016 Clipper 17FQ
2016 Ram 1500 EcoDiesel
2015 Jeep Wrangler Unlimited
Austintatious is offline   Reply With Quote
Old 10-04-2016, 07:37 PM   #19
Our 2016 is doing the same thing in the same area. Seems to me if a bunch of us are having the same problem they either have a defect or a worker that doesn't know how to properly secure the siding working on that corner of all the campers. The dealer I bought mine from is 4 hours away and none of the local dealers will fix it. I found a video on YouTube showing how to remove the corner molding to access the siding so I'm going to try to fix it myself since I'm pretty handy. I bought a roll of replacement gasket and plan to remove the corner molding, detach the siding, re-staple it better and then put the molding back on. Wish me luck lol
bmstephens2 is online now   Reply With Quote
Old 10-04-2016, 07:52 PM   #20
Originally Posted by bmstephens2 View Post
Our 2016 is doing the same thing in the same area....
I'm finding that it's quite common actually. That front area gets hit with different wind patterns depending on the tow vehicle. I noticed that it doesn't do it when I tow with my Jeep but it does it when I tow with my pickup.
Many people mistakenly assume that wind is getting under the siding somehow. But the fact is the wind pattern creates a low pressure area on that front quadrant and "lifts" the siding from the outside. Often it's too much force for the ridiculous staples that are used and they pull out of the studs. The more it happens, the easier it becomes for the staples to slide in and out of the studs.
That's why I'm going to use one or two 1.5" pan head screws at the thicker part of the seam to screw the siding down to a stud. I don't think it will be that noticeable and it will certainly be easier than pulling the trim and siding to get to the area where they are stapled to the studs.
2016 Clipper 17FQ
