Old 06-11-2019, 03:06 PM   #21
Originally Posted by Bilcin View Post
Can anyone tell me exactly what the shrunken material is? Is it a seal? Glazing? Someone mentioned that it is trim. I would like to replace it instead of doing small fixes that apparently will become a common theme as time goes on.
Thank you for your input.Attachment 207055
Look for black sikiflex #201 . on amazon . this is the stuff you want
MR.M is offline   Reply With Quote
Old 06-11-2019, 05:23 PM   #22
If it's on the fixed lite it's a drop glaze seal. If it's on the slider it's an exterior wiper. Could be made from either PVC or EPDM. I can't tell by looking at a photo but PVC will usually turn almost rock hard over time whereas EPDM will stay somewhat flexible. These are usually unique to the window manufacturer so you'll need to identify the manufacturer. Hopefully their name is on the bug (markings) on the glass. I shared a link to Pelland on an earlier post but there are other window parts suppliers also.
woo10-210 is offline   Reply With Quote
Old 06-11-2019, 07:12 PM   #23
Bilcin's Avatar
Thank you so much for the info, if I can't locate the markings I will contact Palomino.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
seal, window
