Old 06-10-2019, 03:38 PM   #1
Bilcin's Avatar
Window seals disintegrating!
2015 Palomino Puma 32DBKS:
All exterior windows have missing pieces of window seals. Can I use clear silicon cualk to fill the voids?
Should I be applying anything to these seals to prevent any further damage?
Thanks in advance for any replies!Click image for larger version
ID:	206936Click image for larger version
ID:	206937Click image for larger version
Bill & Cindy McKenna
Philadelphia PA
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 06-10-2019, 03:48 PM   #2
A32Deuce's Avatar
Looks like the plastic trim pieces shrunk. You may be able to find new or just fill the gaps with Dicore. They have different types. Maybe window glass putty would work.
A32Deuce is online now   Reply With Quote
Old 06-10-2019, 04:18 PM   #3
Bilcin's Avatar
Thanks, so these are the plastic trim and not seals?
Philadelphia PA
Old 06-10-2019, 04:21 PM   #4
A32Deuce's Avatar
That's what they look like to me. They are hard, correct? It just looks like the soft plastic shrunk.
Old 06-10-2019, 04:30 PM   #5
The seals are made of PVC which will shrink and harden over time. The corners are originally sealed with an acrylic seam sealer but that will be difficult to find retail. A black RTV silicone will work well.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is online now   Reply With Quote
Old 06-10-2019, 06:25 PM   #6
Bilcin's Avatar
Yes, they are hard, and my wife said the same thing, they shrunk.
Philadelphia PA
Old 06-10-2019, 06:27 PM   #7
Bilcin's Avatar
Thank you, I am looking for DICOR in black, but on Amazon all they appear to have is white.
Philadelphia PA
Old 06-10-2019, 06:29 PM   #8
A32Deuce's Avatar
You could use black rtv. Just don't use it in place of Dicor anywhere else on your rv.
Old 06-10-2019, 06:38 PM   #9
Bilcin's Avatar
UPDATE:
I just found the Black RTV on Amazon. Thanks.
Should I be applying anything to the seals/trim to help prevent this form happening?
Philadelphia PA
Old 06-10-2019, 06:52 PM   #10
Originally Posted by Bilcin View Post
UPDATE:
Good on the RTV. You don't want to use something like Dicor that doesn't cure semi-firm. Maybe use some 303 Protectant on the surfaces after the silicone cures to block the UV from degrading the surfaces any more than it already has.
You may want to check with Pelland Enterprises to see if they have replacement drop glaze seals.
seal, window
