Old 06-26-2015, 01:19 PM   #1
Window Seals Leaking
The rubber seals around some of my 1992 Coachmen windows are shrinking and pulling away from the frame - leaving a hole in the bottom corner between the seal and the siding big enough I can stick a finger it it. Plus, the rubber is pulling away from the bottom of the window so water is leaking into the wall of the coach. Is this something I can easily fix or is it something a dealer can order a new seal for and replace the old shrinking rubber seal?
BobFlorida is offline   Reply With Quote
leak
