Old 08-28-2016, 03:53 PM   #1
Bilcin's Avatar
Wrinkles on my roof
I have wrinkles on the roof of my 2015 Palomino Puma 32DBKS. There are multiple spots on the roof, front, middle and rear. Is this common?
ID:	118639   Click image for larger version
Bill & Cindy McKenna
Philadelphia PA
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 08-29-2016, 10:04 PM   #2
I have a few spots where the TPO membrane has pulled up, 1-2" diameter. I have a 2015 Solaire. If you can somehow see the roof while driving on the highway and the liner us flapping in the wind that is a problem.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 08-30-2016, 05:59 AM   #3
World Wide Wanderer
wahoonc's Avatar
From the pictures I would say it is within acceptable limits. However keep a very close eye on it. If they get any larger or start to spread you may have an issue. The stuff is glued down using a form of contact cement, it doesn't always get spread evenly.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-30-2016, 07:18 AM   #4
Bilcin's Avatar
Thanks, it was about 92 degrees out when I took the pictures, I would assume that the wrinkles wouldn't be as bad when the temperature drops?
Philadelphia PA
Old 08-30-2016, 07:39 AM   #5
Not many like my solution but it has worked for me several times . I get some brass carpet tacks , the kind that have serrations on the shanks and flat heads , drive them in to the ply under neath and cover with the proper self leveling caulk . Works better than glue . One of my wrinkles was so large that I cut away some fabric and nailed her down , held for three years before I swapped her off !
wanderingbob is offline   Reply With Quote
Old 08-30-2016, 08:47 AM   #6
World Wide Wanderer
wahoonc's Avatar
They should go down some. I wouldn't worry about them unless they get bigger, or they start to bubble up when you are driving. About the only way you can tell that would be to either ride on the roof or use a GoPro. But if the wind is getting into them you should see them start to get larger.
Aaron
Aaron & Rhonda
Old 08-30-2016, 02:27 PM   #7
Bilcin's Avatar
Wife has the roof ride to check out the wrinkles. Thanks for the reply
Philadelphia PA
Old 08-30-2016, 02:42 PM   #8
Flybob's Avatar
Small bubbles like that are not uncommon. Once the temp drops, they will go back down. The integrity of the membrane is still intact. I would not compromise the integrity of the membrane just to get rid of bubbles you can't really see.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-30-2016, 07:08 PM   #9
btritschler1437's Avatar
Per the Dicor rep at the FROG Rally, the best thing for small bubbles is to leave them alone. You should mark them with a ballpoint pen to see if they enlarge. Don't use a black felt tip pen, the ink may not go away, then you could have a bunch of black circles on the roof. As a last resort Dicor makes roof patches, that can be applied to cut or torn roof material. The size you have I would leave them be, but keep an eye on them.
Bob & Sharon, "15 Cedar Creek 38CK Custom, '13 RAM 3500 Laramie, 4x4, LB, CC, DRW 6.7 Cummins HO, Aisin 4.10"
btritschler1437 is offline   Reply With Quote
Old 08-30-2016, 08:13 PM   #10
Bilcin's Avatar
Thanks, and yes, the roofing membrane appears to be intact, and as long as this is a common thing I will simply let it be.
Philadelphia PA
roo, roof
