Old 05-26-2011, 12:07 PM   #1
A&E Awning
I was told by some fellow RV'rs that I should not tie down my awning, however! I have seen it done. Can I tie down the awning and leave a little slack in the tie downs with out any danger of ruining the thing?
Thanks for the responses.
Arizona Garry and Bobbi
2011 Rockwood 2604SS
2006 Ford F150 4x4
Arizona Garry is offline   Reply With Quote
Old 05-26-2011, 02:24 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
It depends on the type of awning. Is it powered or manual?? There are items that look like a corkscrew that screw into the ground and have a strap that goes over the awning. Some awnings have a auto retract when sustained winds occur. We have that type and I would NOT tie mine down for that reason and the fact I'd need a ladder to get close to the rail.
Amazon.com: Valterra Products, Inc. A30-0200 Happy Hook Awning Tie Down: Automotive
http://www.campingworld.com/shopping...ng-straps/2359
Just a couple of examples.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 05-26-2011, 02:30 PM   #3
Herk7769's Avatar
My A&E powered awning was nearly ruined when I tied it down using a sun shade in the accessory rail. A VERY mild breeze came up and the flapping against the bungee cords was bending the T connection where the air spring hits it at 90 degrees. It also started pulling the bearing opposite the motor away from the roller.
I say leave the tie downs to the manual awning folks. IMO.
HAM CALLSIGN - KC3FFW
Old 05-26-2011, 04:29 PM   #4
Read my post on 4/25/2011 #7, I treat it just like the (Non power) type A&E! We put our sunshade in the rail (21) feet ,lower it on one end for drainage,prop it up to clear the door ,all just like the old type. If a storm is coming,its your call to roll it in,same as the old type! Youroo!!
Old 05-26-2011, 04:38 PM   #5
Herk7769's Avatar
All kinds to make a world!
It really worried me when I saw that beam bend.
Old 05-26-2011, 07:11 PM   #6
Arn
Arn
I always tie my 21' power awning down the way I did my manual one. I use the corkscrews in the ground with ratchet straps & always lower one end. I put light weight bungee cords over the awning tube to hook the straps to. This allows the awning to flex in the wind & it is very fast to remove them if I need the awning closed in a hurry. The only time I close the awning is when I leave the trailer or in extreme weather conditions.
Arn
Arn is offline   Reply With Quote
Old 05-27-2011, 06:01 AM   #7
If you want to see the beam (roller tube) bend ,look at one in transit,flexing up & down on every bump in the road. Then you know why they put center supports on the long awnings. Youroo!!
Old 05-27-2011, 06:44 AM   #8
Herk7769's Avatar
You misunderstood. It was not the roller tube that was bending; it was the side supports. There is a shock strut that is 90 degrees to an aluminum channel that bends A LOT when the awning is tied down.
I will try to get some photos today.
Old 05-27-2011, 07:08 AM   #9
Like my past posts said,(Car port),I made adjustable poles that go under the roller tube. They support the roller tube vertically,then you attach the ropes at a 45 to the ground,same as the manual type. If you dont support under the tube yes it will bend the linkage arms,as well as (Never) tighten the awning material. Think carport! Youroo!!
Old 05-27-2011, 09:57 AM   #10
Herk7769's Avatar
A photo would help me visualize what you made to support the roller.
Lou
awning
