Old 08-02-2012, 06:04 PM   #11
TURBS's Avatar
I thought this unit was new .
In that case if you just started having problems I'm guessing the pivot pins are getting froze up.
Going out I believe the shocks help awning motor take awning out. going in the shocks fight it .
You might have to remove shocks and lube all pivots while rolling in and out.
Ron
Old 08-02-2012, 06:16 PM   #12
[QUOTE=f1100turbo;231508]I thought this unit was new .
Ron
The 5th wheel has been stored for about a year and a half and when I extended it out for the first time it worked great. It retracted good as well but when I tried it again and extended it all the way out it would not retract. I did lubricate the pins but it didn't change so now I have a couple of things to check out. Such as making sure the vinyl is evenly distributed on the tube and at the trailer, check the shocks and make sure none of the pivot pins are stiff. You and another person have made suggestions and I am going to do what you both have recommended and go from there. Thanks for your help.....
jgrayjr is offline   Reply With Quote
Old 08-02-2012, 06:28 PM   #13
TURBS's Avatar
Good luck let's us know how u make out.
Old 08-03-2012, 03:12 PM   #14
I lubricated everything on the awning arms. I tried to center the vinyl fabric on the tube but it got hot before I could work on it and the vinyl would not move. I did however get it better centered and the awning does retract but does have a little problem getting started but once it starts it retracts well. I will wait until the weather cools off and the polycords shrink to try to center the vinyl any further. Thanks
Old 08-03-2012, 04:17 PM   #15
realebill's Avatar
[QUOTE=jgrayjr;231507]
Originally Posted by dunnnc View Post
Once you get it straightened and centered, you need to pop rivet the hem to the tube on both ends to eliminate it from "racking" again. Herk has a picture of how it looks after it is finished.
I went out and checked the awning again and found that the vinyl has shifted to one side both at the trailer and on the tube. There is about six inches between the vinyl and the end of the tube on one end and about a couple of inches between the binyl and the end of the tube on the other end. Is that enough to cause friction to not retract very good?
I will pull the trailer out tomorrow and extend the awning and see if I can center the vinyl both at the trailer and on the tube. I think I can put a small screw at both ends of the vinyl at the trailer and pop rivet the vinyl on the tube once it is centered as well. I will let you know if your idea works. Thanks
that's about how much mine was off center. took a couple of trys centering and rolling back in and out but i finally got it centered properly to where the arms were centered when it was retracted up against the trailer. when i was satisfied that it was retracting centered,i drilled and pop-rivited the awning in place on the roller.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 08-03-2012, 04:40 PM   #16
[QUOTE=jgrayjr;231507][QUOTE=dunnnc;231474]Once you get it straightened and centered, you need to pop rivet the hem to the tube on both ends to eliminate it from "racking" again. Herk has a picture of how it looks after it is finished.
Who is Herk and where is the picture you are referring to?
Old 08-03-2012, 04:52 PM   #17
[QUOTE=jgrayjr;231915][QUOTE=jgrayjr;231507]
It is a picture I took after pop riveting my awning which Herk likes to show as an "Over-extended" awning, which is a no-no,
Some folks say this is wrong that the cords in the tube will hold it, but of the 8 awnings I've had, none have had the cords "Cut correctly" from the awning mfg.
So I guess the awning mfgrs don't even know how to do it correctly.
Name:	Pop Rivet in Awning.jpg
Old 08-03-2012, 05:39 PM   #18
Still don't find that picture you are referring to. Can you enlighten me as to where it is at? Thanks
Old 08-03-2012, 06:00 PM   #19
Herk7769's Avatar
[QUOTE=jgrayjr;231941][QUOTE=jgrayjr;231915]
Are you able to see the photo in post #17?
HAM CALLSIGN - KC3FFW
Old 08-03-2012, 06:48 PM   #20
I am new to this forum so I have no idea where post #17 is?
awning
