Old 05-17-2017, 01:00 PM   #1
Adjust Awning
I am having a issue with my awning where the arms do no align correctly when I close it up.
Here is what it looks like when I close it up
The tube looks like it is bowed but not sure how much that will hurt
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
Super8mm is offline   Reply With Quote
Old 05-17-2017, 03:23 PM   #2
brookstone345sa's Avatar
I had same problem. Open up awning and look to see if it is straight in line with part attached to camper. Mine had slipped a little. I had to slide the canvas to line it up and that fixed the problem. The part attached to camper has end screws, but the open end does not, it is just slid onto the round roller.
brookstone345sa is offline   Reply With Quote
Old 05-17-2017, 03:41 PM   #3
Herk7769's Avatar
It should be screwed in at the wall rail and free to move on the roller.
With a person on both ends, flap the awning material while tugging it so it is square with the rig wall.
Once the awning retracts correctly, shallow drill and pop rivet one end of the roller to lock the awning in place.
HAM CALLSIGN - KC3FFW
Old 05-17-2017, 03:54 PM   #4
Sorry to disagree Herk, should pop rivet both ends.
Old 05-17-2017, 04:00 PM   #5
Iwannacamp's Avatar
They make stiffener type things to slide into the awning tube for the bowed condition. My old 5er had about an 18 ft. awning and it bowed a little...the new one has a 20 or 21 ft awning and I am wondering about it. The repair is a star looking piece that goes in the tube,
2017 Puma 297RLSS
Old 05-17-2017, 05:25 PM   #6
Thanks guys, the open edge of the awning looks to be narrower that the edge attached to the wall.
Do I start moving it in the right as it looks like it is running off to the left?
I will have to look for that rod that slides into the roller tube
2013 Puma 356QLB
Days Camped 33
Miles 6450
Old 05-17-2017, 05:30 PM   #7
The material should be centered on the roller as close as possible. It may take running it in and out several times to make sure it closes all the way.
Old 05-17-2017, 05:43 PM   #8
I will find center of the material on top end and measure it to one side and then do the same with the roller and start moving the material.
2013 Puma 356QLB
Days Camped 33
Miles 6450
Old 05-17-2017, 06:14 PM   #9
Just as confused as you
Scrapper's Avatar
My awning on the slide does the same, just only on one arm, not both. Just looking at it extended and closed it looks square. Haven't measured it yet. Started it shortly after we got it. It's on a seasonal site and never gets towed.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 05-18-2017, 07:09 AM   #10
Herk7769's Avatar
I know we pop riveted both ends in my old and current awning, but I am concerned now that the awning material will warp as it shrinks and bow long rollers. Might be overkill to think that way.
awning
