Old 07-15-2013, 07:40 PM   #1
Exclamation Another Awning Problem
i have a 2009 flagstaff 831fkss and the power awning goes out fine but when i try to close it up it dont move except when i get up there and help it but not hard i give it a little trun and it goes and then stops again all the way closed
jrg81471 is offline   Reply With Quote
Old 07-15-2013, 09:30 PM   #2
VinceU's Avatar
Sounds like too much friction in the shaft bearings and the pivot joints of the framing. Take a can of "Dri Lube", many brands available. No Oils! Lube every thing that moves or slides. Should be much better. Don't delay, the motor will quit.
