Old 08-05-2015, 07:03 PM   #1
Awnbrella awning supports
Has anyone installed a set of Awnbrella awning supports on a Sandpiper 5th wheel trailer? My 32QBBS has a 20 foot awning and it looks like it needs support when it's full extended out.
Also anyone installed a awning cradle support?
jamsr is offline   Reply With Quote
Old 08-05-2015, 07:30 PM   #2
Done with this
Where is Turbs and OC???
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 08-06-2015, 05:52 PM   #3
I'm not following you? What is Turbs and OC??
Old 08-06-2015, 06:09 PM   #4
rowdydog77's Avatar
They are people that sell poles (Turbs) and supports (OC).
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 08-06-2015, 06:12 PM   #5
rowdydog77's Avatar
OC = Old Coot (handle)
Old 08-06-2015, 06:25 PM   #6
yes jamsr, I have used the awnbrella supports on 2 different 18foot awnings. They worked great. I kept the rvs in a seasonal site. I used 3 awnbrella supports and tied the ends down. The awnings were extended for the whole season. 4 seasons total. bought 3 sets of 2 supports between my brother and I. He used 3 and I used 3. 4 would have been better but 3 worked. Awning went thru storms and very high winds with no issues. One of the awnings was a manual and the other was electric.
I have 2 awnings on my present 5er. An 8 footer and a 9 footer. gonna use 1 awnbrella support in each and tie em down. Nice part is I can tilt the awnings lower on one end when I leave the camper or if I know it's gonna storm.
Semi retired now and enjoying it.
2013 F150 Super Cab 4x4, 3.5L ecoboost , 7700lb suspension package. 11,300 towing capacity and Max Tow package
2015 Flagstaff 8528IKWS Diamond
aquaholic3 is offline   Reply With Quote
Old 08-07-2015, 05:07 AM   #7
arpipeliner's Avatar
Go to the general page and the bottom is the classified section. You can find OC brackets and Turbs poles. Pictures and prices. They work. My suggestion.
Name:	ImageUploadedByForest River Forums1438942018.641017.jpg
OC brackets and poles from Lowe's on my camper.
arpipeliner is offline   Reply With Quote
Old 08-07-2015, 05:22 AM   #8
Attachment 85078
You guys are missing the OP's point............he asked specifically about Awnbrella supports. they aren't support poles. They're for putting a bow into the fabric itself stopping the fabric from flapping and ever pooling water. They work perfectly for that scenario. You can also use the support poles with them.
Old 08-07-2015, 06:12 AM   #9
They want you to install these every (4') for proper install,trying to (Clean) your awning with these installed is a Real Pain! Also even if you (Use/Install) these you (STILL) need to Tilt your awning for (Proper Runoff/Protection) or (Damage Can/Will) happen from Rain! Use support poles that you can Tilt/Adjust for Proper Runoff when you (SET UP) then you DONT have to WORRY with (Rain/Wind) within (Reason)! Your Call! Youroo!! Just remember the (Elect Awning) can go UP Over the Top also! Support for Safety!
Old 08-15-2015, 06:10 PM   #10
Thanks for all the good information on the Awnbrella supports. I plan to install my next weekend.
Has anyone installed a awning cradle caddy and if so what is the easiest what to find a wall stud?
Old 08-25-2015, 12:11 AM   #11
I have an awning cradle installed for my 21 ft awning. The instructions did not indicate the need to attach to a wall stud. I didn't and have not had any problems in 3 years and many rough highways and gravel roads.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
awning
