Hi hint1104. I see it is your 1st post! Welcome.
If you have an electric awning, there are ways to tie it down.
There were a couple members here that were making the parts necessary but sadly, both seem to have moved on. Old Coot & Turbs.
If you do a search for awning tie down you will get lost of hits on past discussions and maybe you will get an idea of what is necessary.
I believe the .PDF file for the brackets from Old Coot is in the Library section at the top of the page. (using a browser)
Here is one such search...
Awning Tie Down
Here is a photo of my awning poles and brackets from Turbs.
They are in the stowed position here and not deployed.
If I can find a photo of them deployed I'll edit this post.
Here is a link to a post from Turbs several years ago showing detailed instructions/photos on how to install an awning tie down kit.
Turbs Awning Pole Installation
